Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Sun Auto Hyper Force! Plug and Play
Old Jun 21, 2006 | 11:44 AM
InjectedPerf's Avatar
Sun Hyper Force System is new high-efficiency ignition tuning and strengthening system by Sun Automobile. Hyper Force System focuses on direct ignition engines and is available in 4 and 6 cylinder versions.
It will work on these vehicles: Mitsubishi Lancer Evolution (CT9A), Subaru WRX (GDA/GDF), Nissan 350Z (Z33), and Nissan SR20DET (S13, S14, etc.)
Benefits Increased Engine Response
Improved Fuel Efficiency
Increased Horse Power and Torque
Reliable ignition spark throughout the entire rev range
Reduced emissions / stabilized idling
Included Components Main Unit (1), Mounting Bracket (Set), Zip Ties (3), Wiring Harness Adapter (set) Description: Problems associated with ignition coils and the capability of the Hyper Force System?
A normal ignition coil inherently generates back electromotive force (*1back EMF) during operation. This back EMF negatively affects the ignition device inside the coil, decreases plug voltage, and negatively affects plug efficiency. With this problem, voltage not only becomes unstable but also produces ignition time lag in the next ignition cycle. HYPER FORCE SYSTEM works by absorbing all back EMF, which aids to improve plug voltage and promote complete combustion by producing 100% coil efficiency. Furthermore, HYPER FORCE SYSTEM eliminates any ignition performance loss due to decreased electrical current under heavy throttle.
Since ignition efficiency over the entire rev range improves, available torque and acceleration response improves; this efficiency enhancement also contributes to better fuel efficiency and a reduction of harmful emissions.
PM for Pricing.
Old Jun 28, 2006 | 01:16 AM
blazinasian's Avatar
Curious as to where you plug in everything? Where would you mount this in the engine bay? Is there a pic of it installed? This is plug and play so no programming needed right? I'm guessing this is something like a grounding kit but more advanced.
Thanks and take care.
Old Jun 28, 2006 | 06:52 AM
g-adabout's Avatar
any dyno numbers to back it up? we as a nation are addicted to numbers!!!
Old Jun 28, 2006 | 02:53 PM
speeddreamz's Avatar
Sorry to say but, it looks like one of those increase by 20 hp magic chips and computers on ebay. Which of course are completely bull****. The only way this system would work is if its like HKS twin power ignition, or if it can adjust ignition timing by retarding or advancing, and given its programable.
Old Jul 1, 2006 | 06:37 PM
EricIsKlumzyee's Avatar
no a stronger spark will be able to make more power.. it'll light mixtures with a strong spark.. weather it works or not is another question lol.. it will also allow you to up your compression (if u ever decide to rebuild) and it'll let you advance your timing further
Old Nov 15, 2006 | 11:17 AM
Back up!
Old Dec 5, 2006 | 11:11 PM
ttrank's Avatar
Grocery getter
Originally Posted by InjectedPerf
Back up!
Never saw any replies to questions. Just a bump..?
Old Dec 6, 2006 | 10:06 AM
The hyperforce is an ignition grounding system. This system is designed to improve the efficiency of the coilpacks by reducing the backflow of voltage through the coils after ignition occurs. According to Sun this unit also helps to deliver more energy to the plugs.
We do not have any dyno graphs on this system for the Z. I have sold a ton to the EVO community. They have all been very pleased. What they noticed is smoother idle, all around smoothness throughout powerband, lastly less break up at top in high boost conditions.
I have seen dyno numbers anywhere from 2-8 whp.
Old Dec 21, 2006 | 04:36 AM
Omeezy's Avatar
How much shipped 30314? Thanks
Old Dec 21, 2006 | 11:31 AM
pm sent.
Old Dec 21, 2006 | 03:46 PM
pm sent
Old Feb 28, 2007 | 05:23 AM
G35Five_O's Avatar
Still sell these???
Shipped 96797
Thanks
Old Mar 5, 2007 | 04:19 PM
pm sent.
Old Mar 5, 2007 | 04:46 PM
extreme4377's Avatar
Lexus IS350
Price to 92014 please
Old Mar 5, 2007 | 04:50 PM
izmir41500's Avatar
G35driver Addict
shpped to 75038
