Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
*NEW* Turbonetics G35 Single Turbo Kit
Old Oct 25, 2005 | 01:24 PM
  #106
MIAPLAYA's Avatar
Originally Posted by G-Mann
if i get this kit, im ganna swap it out for the turbonetics Godzilla BOV. that soudns sooo B.A.
its more like a "vrroooom tulfffff" rather than a pshh
The Raptor actually sounds very similar to that...
Old Oct 25, 2005 | 07:01 PM
  #107
TurboKits.com's Avatar
I have a received a few PMs about the link to the Group Buy not working...
Try this: https://g35driver.com/forums/group-buys/71280-turbonetics-st-g35-kit-group-buy.html
Sorry if it caused any inconvienence...
Thanks
Jesse @ Turbo Kits.com
Old Oct 25, 2005 | 07:38 PM
  #108
coupin827's Avatar
Jesse, just remember, only premier members can see the Group Buy section.
Old Oct 27, 2005 | 09:04 AM
  #109
That explains alot!
Try this -
Originally Posted by turbokitscom
Hello All,
We wanted to switch our offer to a Group Buy set up for the TN ST kit. This will allow us to price it better than Wholesale. We only need 3 people to get these prices. The GB is good until Nov 30th, a $500 deposit will hold the kit in your name (On Dec 1st Turbonetics is increasing the retail $400 so expect prices to go up accordingly).
Please PM me for pricing. This WILL be the lowest price offered!
G35 Coupe Turbo Kits Include:
- Turbonetics T60-1 Ball Bearing Turbo
- Polished Mandrel-Bent Exhaust Pipe
- 2.5" Stainless Mandrel-Bent Downpipe
- Turbonetics Evolution 35mm Wastegate
- Spearco W.A.V.E Front-Mount Intercooler
- Dual Fan Intercooler Shroud (Cooler Air!)
- Turbonetics Raptor Blow Off Valve (BOV)
- Turbonetics AF-1 Air Filter
- Black Chrome Mandrel Aluminum Piping
- (6) 380cc Injectors
- Walbro 255LPH Fuel Pump w/ Install Kit
- Turbonetics Full ECU Re-Flash
- (1) Case TS-1 Synthetic Turbo Oil
- Install Instructions & Wiring Diagrams
- All Necessary Hardware & Fittings
The DYNO is for the 350Z but Turbonetics has told me the # are within 3 HP & Ft Lbs of eachother.
The Intercooler uses a dual fan system with shroud to help cool the charge. This was done to increase the airflow through the intercooler that is lost due to the side vents on the stock front fascia. Also, the fan motor voltage drops 50% at idle so they are whisper quiet then pump back up once the engine is revving. According to Turbonetics this offers cooling better than a plain FMIC.
More Info: http://www.turbo-kits.com/g35_turbo_kits.html
We also have built shortblocks, headwork, custom 1 of a kind 3" true dual exhaust, clutches, flywheels, Injectors, ECU. We can bolt on 400HP safely on your stock engine or build you a 1000HP block
We can also offer the eManage Ultimate upgrade for all you 05 guys.
Let me know if you guys have any questions
Turbo Kits.com - Avon, CT
jesse@turbo-kits.com
860-676-2929
AIM: Turbo Kits Com
P.S. Turbonetics will offer the AUTO Tranny version in a few months after this is released
Old Oct 28, 2005 | 03:47 AM
  #110
mrjonang's Avatar
will there be a GB price like this for the AUTO as well?
Old Oct 28, 2005 | 02:18 PM
  #111
Pearlcoupeg35's Avatar
Any info, pictures, video, stories, etc about a G35 Coupe with the turbonetics kit installed and running?
Id love to see some more on this kit, bit im tired of looking at 350z with it...
any G's have this setup? wanna share some info?????
Old Oct 29, 2005 | 08:53 PM
  #112
G-Mann's Avatar
anyone know what 1/4 times the turbonetics 350zs are putting out? id say low 13s, high 12s?
Old Oct 30, 2005 | 01:07 AM
  #113
G2FAST's Avatar
+1.............
Old Oct 30, 2005 | 09:38 AM
  #114
MIAPLAYA's Avatar
Between 12.4-12.7 with trap between 110-115
Old Oct 30, 2005 | 09:39 AM
  #115
MIAPLAYA's Avatar
Originally Posted by G2FAST
+1.............
Check out the recent Sport Z for a full write up and review on the Turbonetics G kit. There are a few in New Mexico in addition to Brad from Turbonetics...
Old Oct 30, 2005 | 02:10 PM
  #116
Meatshackle's Avatar
Deep Sea Moderator
Lucky New Mexicans...........
Old Oct 31, 2005 | 12:51 AM
  #117
G-Mann's Avatar
so what would that translate into G terms? 12.8/9
Old Oct 31, 2005 | 10:36 AM
  #118
I am sure we will run a special of some kind. However, the current pricing reflects a $400 pre-order discount directly from Turbonetics which goes away Dec 2nd. I am not sure if they will be offereing the same type of promotion when they release the AUTO version.
However, we always give the best pricing we can
Old Oct 31, 2005 | 10:38 AM
  #119
Hey Guys,
If I happen to dissapear this week. I am going to be away at the SEMA show. I will be back on the scene first thing Mon morn the 7th.
I will try to round up some fresh pics of the car w/ install and try to see if I can get some vids of it in action...
Old Nov 3, 2005 | 12:50 PM
  #120
mooka's Avatar
Sorry guys but what is up with the Torque curve, how should I read that.. 1500 ft/lbs at 6000K?
Also wheres all the bottom end torque?
