FS[SoCal]: Brand New Coupe HD Trunk
Old Jan 21, 2014 | 07:54 PM
terrorx7's Avatar
Well after stripping 1 of the 4 Torx screw I'm at a crossroad and will not attempt to remove oem trunk. This is brand new and unmounted so I do not know fit and finish. Trunk will need to be prepped before painting anyways. There is a tiny chip I do need to mention but can easily be covered before painting. I'm in the Lake Elsinore area and this is for local pickup only...I could meet you anywhere within a 50 miles radius for a little extra. Willing to trade for a Nismo S-tune exhaust +cash on my end. SOLD
Old Jan 21, 2014 | 08:46 PM
g06driver's Avatar
Will you trade for the same trunk but carbon fiber +cash on your end? I will even help you install the trunk
Old Jan 21, 2014 | 08:49 PM
terrorx7's Avatar
Sorry bro...if I could get oem trunk off I would prefer new trunk to be painted.
Old Jan 21, 2014 | 09:09 PM
g06driver's Avatar
well just an FYI..if you search you will find that those torx are a VERY soft metal and so far I don't think anyone has successfully taken them out undamaged. You have to drill them out. That's what i did with mine too it's super easy. let me know if you need help doing it.
Old Jan 21, 2014 | 09:46 PM
terrorx7's Avatar
Thanks...I did noticed/read that...I mean the 1 torx I barely touched and it stripped If I plan on keeping this I will probably get another set of trunk hinges from eBay.
Old Jan 21, 2014 | 10:22 PM
g06driver's Avatar
the only thing you should need is just new bolts for the hinges...use the smallest drill bit you have and drill out the torx bolts and reuse the hinges with new hardware.
Old Jan 22, 2014 | 02:56 AM
J0hnblaze's Avatar
Would u take other stuff for trade?! Like a motordyne xyz pipe or a furookie intake?!
Old Jan 22, 2014 | 03:27 AM
terrorx7's Avatar
PM you
Old Jan 22, 2014 | 06:01 PM
xFALCONS7x's Avatar
I just took off my oem trunk last week. All 4 torx bolts were stripped, do i just took a flat head screwdriver and bent the bolt up a bit then took vice grips and grabbed the bent piece and turned counter clockwise. It should take you about 30 min to get all 4 out. Then just got 4 new m6 10mm bolts and install is easy. If you have a winged trunk now you will be very happy you decided to get rid of it!!! Wingless FTW
Old Jan 22, 2014 | 06:08 PM
xFALCONS7x's Avatar
This is what the new bolts look like
Attached Thumbnails Brand New Coupe HD Trunk-image-3568401711.jpg   Brand New Coupe HD Trunk-image-1457638451.jpg
Old Jan 22, 2014 | 10:28 PM
HenryLee's Avatar
This happen to me. You just need to by the reverse drill bit to get the screws out. Happens to everyone.
Old Jan 23, 2014 | 08:53 PM
digit2k5's Avatar
Put the torx bit in and hit the end of the handle with a hammer.... it'll break them loose. That's what we do in the shop everytime for door latches and other stubborn bolts. Also how I got mine outta my trunk before putting my master grade on
Old Jan 25, 2014 | 11:01 AM
RICKY909's Avatar
HD trunk
am interested do you still have it? if you want I can meet you at Ontario mills let me know what you think. thanks
Old Jan 25, 2014 | 11:45 AM
terrorx7's Avatar
PM'd you.
Old Jan 26, 2014 | 04:27 PM
terrorx7's Avatar
Sold... Thank you.
tal1412
Nov 28, 2022 09:25 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
G35_EAZY
Jul 19, 2015 01:38 PM
Tylerttn
Jul 16, 2015 10:33 AM
