LEDmarkers G35 LED third brake light replacement
I have some if you need a new one but if you bought a brand new board and it doesnt work I don't think the board is the problem. The brake lights work on the taillights? (I don't remember the circuit but I think the running lights are irellevant. Make sure the BRAKE lights still work)
Best bet is to ensure your third brake light is getting proper ground and good 12v with a multimeter. You can also bench test your third brake light with a 12v power supply.
If it does turn out that the brake light is bad I can help you out with a new one
So if i test my light and it doesnt work, i need your mod, right? I connect light to the battery and it didn't light up. Noob here.
All I can say is that my light will work when power is applied to it
I bought the LEDmarkers interior "3rd tail light" LED replacement for my 03 G35 Coupe. Got it quickly from the vendor, but there are absolutely NO instructions on how to access/remove the rear deck lid 3rd tail light housing. This is very complicated process and the LED strip replacement product is utterly useless without these pertinent instructions. Also, their "instructions" via someone else's youtube video does not link to a video addressing the removal process in a coupe. At present it looks like I will be returning the product due to this lack of information.
After fiddling around in the coups trunk and dropping the upper liner (as seen on youtube video for the sedan), I went into the cabin and simply used a large flat head screw driver to lift the third tail light mounting. It is simply a snap in/on housing like it should be. There is NO screw securing the housing from inside the trunk.
It took a bit of fitting but the LED sold to me by LEDmakers was installed and is working.
So, from what I remember, there is no real need to mess with the trunk liners in the G35 coupe at all. Just carefully lift the housing from inside the cabin with something thin and flat so that no gouge marks are left.
I guess I got lucky cause they send me the correct product lickety split.
Hasanbaloch
Feb 29, 2024 08:45 PM
bTanz
Oct 15, 2015 02:31 PM
