FAQ & DIY Frequently Asked Questions & Do It Yourself- Sedan and Coupe. Updates Approved by Administrators and Moderators.
Double Clutching
Old Jun 4, 2004 | 12:45 PM
lucidazn's Avatar
Double Clutching
I've read here and there on a little about double clutching. I don't really know what it is. I have a some questions hopefully you guys can answer.
1. What is it? How do you do it?
2. What purpose does it serve?
3. Does it harm the engine in anyway?
Thanks guys =D
Old Jun 4, 2004 | 02:05 PM
mamboking's Avatar
Re: Double Clutching
I can't add any more. Perfect explanation Mr. Elussive. I remember when I was a kid (60s) seen my dad double clutch his Ford F-100.
Old Jun 4, 2004 | 02:10 PM
Speedoholic's Avatar
G (enie) FUNK ERA
MrElussive is right.
A more efficient way of double clutching (and also what MrElussuve described) is called rev-matching.
When you down shift from a higher gear to a lower one (say 4th to 3rd or 3rd to 2nd), what happens is you create an excessive wear on the clutch due to a jump into higher RPM on the engine's behalf in order to catch-up with the revolution speed of the clutch disk. Rev-matching allows you to downshift while conserving the life of the clutch. To rev-match: depress the clutch, down shift, blip the throttle, and release the clutch. When you do that, you bring up the RPMs of the engine (or the flywheel if you wish), to match the revolution speed of the clutch disk - thus creating less tear while the two disks re-engage.
I hope this makes sense....
04 6MTC DG/G/Prm/NAV/C.Crnrs/C.Br/A.ped/Polk/PIAA/Grnd.Kit/Rebadged/JWT Pop Charger/Z-Tube/Spl.Grds
Old Jun 4, 2004 | 03:07 PM
GMan6's Avatar
Actually despite wear on the clutch, double clutching (rev matching) serves a very important purpose. It maintains balance of the car. If you just downshift and let the syncros do the work the car lurches from the sudden rev match, do that at high speed in a corner and your toast. Rev match properly and the balance doesnt shift so you maintain complete balance and can accelerate/brake under control.
Old Jun 4, 2004 | 03:13 PM
gto2050's Avatar
Double clutching was done with non-synchronous transmissions and it was necessary to rev-match the trans/engine before the shift could actually be mad without grinding. Some commercial applications still use it but not cars. A simple blip of the throttle and expereince is all that is required for "rev-matching".
Old Jun 4, 2004 | 04:17 PM
sen_jen's Avatar
Meatshake Enterprise
i rev match often. ever since my honda's!
Old Jun 4, 2004 | 04:42 PM
bsoo's Avatar
old discussion
This subject has recently been discussed at length. See this post:
<a href="https://g35driver.com/forums/showflat.php?Cat=&Board=16&Number=233013&page=6&vi ew=collapsed&sb=5&part=">Heel Toe Shifting Possible?</a>
http://www.imagestation.com/member/?name=bsoo
2004 Coupe 6MT fully loaded incl. side moldings and splash guards, but no satellite radio.
Old Jun 4, 2004 | 04:54 PM
Aznteazer's Avatar
if u clutch 2 times on the same gear and ur car launches for a bit, wat is that called?
i thot that was double clutching.
Old Dec 11, 2004 | 09:08 PM
Aman's Avatar
Haha, I bet the original poster just heard that from the Fast and Furious. Oh well, its ok. Whenever I hear someone say double clutching, I think of an old 13 speed dumptruck!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
BfloG35
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
