Help with SPC Front Camber spacers...
Old Jul 27, 2007 | 11:10 AM
ron4row2's Avatar
Can you guys help me out with a DIY for installing the front spacers with the SCP kit. I installed the control arms and still need more adjustment on the passenger side. This sucks since I only dropped it with the Z springs!
Thanks.
Old Jul 27, 2007 | 11:29 AM
Demonteverde's Avatar
Moderator
https://g35driver.com/forums/brakes-suspension/130848-my-spc-arm-installation.html
Old Jul 27, 2007 | 03:36 PM
Gilley's Avatar
Something isn't installed correctly if you need more adjustment on Z springs.
I used the SPC arms without spacers and I'm on 350Z S-Techs.
Old Jul 28, 2007 | 05:07 PM
ron4row2's Avatar
After the initial drop the drivers side was at -1.0 and passenger side at -1.5. Now I'm at -.2 and -.9. I installed them exactly the same on each side, I even used your DIY. Any ideas?
Old Jul 28, 2007 | 05:08 PM
ron4row2's Avatar
Originally Posted by Demonteverde
Thanks, I used Gilley's DIY when I installed them but he didn't install the spacers.
Old Jul 28, 2007 | 09:48 PM
SFLG35's Avatar
FGC President
what are you trying to get your camber to?
that is already pretty low. i run -1.6 in the front and -1.4 in the rear
im sure you havent maxed out the arms yet, but i done know cause i dont have the spc ones. also make sure to get your camber and toe to be even on both sides
Old Jul 29, 2007 | 09:39 AM
ron4row2's Avatar
That's my goal now. Since I have a sedan I was going tohope for at least -.5 or a bit less in the front and -.7 in the rear. At this point it looks like I can't make it without the spacers in the front.
Old Jul 29, 2007 | 10:19 AM
SFLG35's Avatar
FGC President
ah
didn't know you had a sedan not quite sure what the sedan specs are. i would take it ot the alignment place see if they can get anmore out of the passenger side and then just set the driver side to whatever the pass side is. then just set the rear a little more negative
Old Jul 30, 2007 | 08:25 AM
ron4row2's Avatar
ah
That may be what I need to do since I know there are some problems associated with the SPC arms once the spacers are installed.
Thanks.
Old Jul 30, 2007 | 09:54 AM
Gilley's Avatar
With you having a sedan, you may need the spacers if your drop is low enough. The ride height of the sedan is about 1/2 inch higher than a coupe.
Old Jul 30, 2007 | 11:14 AM
ron4row2's Avatar
It's just off that after I changed the springs. My specs before the front cambers was L -1.0 and R -1.5.
Do you have any idea why that passenger side started out so far off from the other side?
Old Aug 2, 2007 | 12:43 PM
ron4row2's Avatar
Bump
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
cbax
Aug 17, 2015 07:41 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
