G37S on Maya STM finally got them on!
Old Mar 29, 2008 | 05:26 PM
Kidcane's Avatar
So I finally put my wheels on yesterday. I think it looks pretty good but I have run into a couple small problems. The fronts did not clear the brakes so I had to put a crappy 7mm spacer on there and that does not leave me much stud to tighten down the lugs as far as they probably should go. So I ordered hubcentric spacers and longer studs. Then on the rear I am rubbing a little bit over bumps so I am going to have to raise the back up about .25" and remove the insulation under the wheel well. After that I will check the camber and try to get it close to spec.
Here you go...
Old Mar 29, 2008 | 05:29 PM
express705's Avatar
looks clean. nice work.
Old Mar 29, 2008 | 05:30 PM
Gilley's Avatar
It looks like the rear wheels stick out too far. I can't tell about the fronts.
Old Mar 29, 2008 | 05:34 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
That's a nice, aggressive rear, looks great!
-GP-
Old Mar 29, 2008 | 05:35 PM
Kidcane's Avatar
Fronts are dead flush but the rear could be a few mm less. Not sure there is much else I can do about except get a different set. Does it look bad?
Old Mar 29, 2008 | 05:39 PM
MikeYo's Avatar
looks good
Old Mar 29, 2008 | 06:40 PM
JLai's Avatar
Old Mar 29, 2008 | 07:58 PM
SFLG35's Avatar
FGC President
chad
looks awesome!!!!!
dont raise it at all, maybe lower the front a little more!! just add a littl emore negavtie camber and it will look sick. go see christian at lokey and have him do it, tell him just to camber it in like mine, just not as much.
Old Mar 29, 2008 | 08:15 PM
Invalid_User's Avatar
very nice looks real good
Old Mar 29, 2008 | 08:46 PM
big peter's Avatar
Hey, car looks great man. I am not really that hot on the new g37s but yours in black, on those rims changed my mind. +1 on running the camber on the rear. Keep it up!
Old Mar 29, 2008 | 08:51 PM
jaydafunk's Avatar
nice
Old Mar 29, 2008 | 08:55 PM
O HELLA OEM's Avatar
very very nice!
Old Mar 29, 2008 | 09:19 PM
Kenrik's Avatar
Not a fan of black on black but the car looks nice.
Old Mar 29, 2008 | 09:55 PM
Wicked_limitz's Avatar
looks good
Old Mar 29, 2008 | 10:14 PM
m1a2c2kali's Avatar
have you thought about blacking out ur headlights?
