door won't close
Old Aug 29, 2008 | 03:59 AM
JaxShawn's Avatar
door won't close
Well my passenger door has been having some issues closeing the last few weeks, it seem it doesn't properly line up with the body or what ever, i have to pull up and semi-gently close the door to get it closed, other wise the door will open slightly and the window will start going nuts b/c of the up and down feature.
Anyone else have this problem, and wha do you guys suggest for a solution, it's out of warranty, and i'd like to do all the work myself if possible.
Old Aug 29, 2008 | 04:46 AM
NathanJax's Avatar
..... I WIN .....
My old trans am would do this. It was the hinges holding the door on. They bolts were loose. Had a friend hold the door up, while I tightened, everything was ok.
Hopefully that's all it is... I know someone who had to replace the metal that attached the hinges to the car itself, because the welds were breaking loose...
Good luck !!!
Old Aug 29, 2008 | 08:50 AM
w0ady's Avatar
fgc moderator
probably just the bolts unless the hinges all of a sudden got bent.
Old Aug 29, 2008 | 05:58 PM
Gilley's Avatar
That's the first time I have heard of a sagging G door.
If you car is under warranty, take it in to the dealer. Otherwise, a body shop can help.
Old Sep 11, 2008 | 02:23 AM
JaxShawn's Avatar
Fixed the problem, somehow the part that catches the door got out of whack.
Old Jun 15, 2011 | 02:49 PM
bor99's Avatar
This is happening with my '03 coupe. The driver's side door doesn't always close completely and sometimes it takes a few tries to close. Just started happening 2 days ago.
Old Jun 15, 2011 | 03:02 PM
iamericgee's Avatar
Old Jun 15, 2011 | 03:07 PM
nghiars's Avatar
check the hinges as well as the locking mechanism to make sure it's all alighend and working correctly.
Old Jun 15, 2011 | 08:07 PM
blAk mAx's Avatar
great scot marty !
Old Jun 16, 2011 | 01:37 AM
bor99's Avatar
Originally Posted by iamericgee
Haha, tried searching because I know how much forums like when people start threads for the 3835th time.
Tried looking around, everything looks ok. Sometimes it lines up perfect, sometimes it doesn't.
Old Jun 17, 2011 | 12:07 PM
bor99's Avatar
So, I kinda figured out how to close it, I just push down a bit. It closes fine, but now the window won't roll up or down. And it doesn't roll down/up a bit like it used to every time I opened the door.
Old Jun 17, 2011 | 11:10 PM
bor99's Avatar
Update:
It started closing fine, but the window wouldn't go down. I read here that if you open your door, then hold the down window button, it would go down once you close the door. I did that and now it goes up and down fine. Hopefully it will stay like that!
Old Jun 18, 2011 | 12:10 AM
Sen's Avatar
Sen
My locks and windows act up sometimes when it's really hot out. But seems to work just fine during non "hot as *****" times. Florida heat for you, I guess.
Old Jun 18, 2011 | 02:57 AM
bor99's Avatar
That's weird! It wasn't too hot/cold out today. About 75 or so.
Old Jan 9, 2013 | 06:04 PM
angelatrang's Avatar
Unhappy
How did you fix this problem? This started happening to my 03 coupe today
magnetism80
Feb 1, 2019 10:00 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
yosip1115
Sep 9, 2015 03:30 PM
jbmw002
Sep 3, 2015 08:42 PM
