S & R PERFORMANCE open ecu reflash
Old Dec 2, 2008 | 08:15 AM
iamericgee's Avatar
Question S & R PERFORMANCE open ecu reflash
Hey Guys,
Have you done lot mods to your car and have not tune it? Because you’re afraid of putting a piggy back or just high cost of it.
S&R Performance is offering to do an open ECU flash for $500.
This only for group for a minium of 10 people!!
This is a discount from the normal reflash of $750
Parameters that we will tune include:
Up to 3 Maps on cruise control equipped vehicles, Idle RPM Speed Limiter Electronic Throttle Control to achieve Wide Open Throttle at all speeds. Rev Limiter DTC disable, AFR Targets Fuel Compensation, Ignition Timing Advance Cam Phasing for equipped vehicles.
anybody interested in this ?
http://forums.350zclubofflorida.net/...ead.php?t=1988
Old Dec 2, 2008 | 01:50 PM
_jb's Avatar
_jb
Photographer
Originally Posted by HYDROERIC2003
Hey Guys,
Sounds like UpRev's Osiris Tuner Pro...
That was quick...
Old Dec 3, 2008 | 09:04 PM
s&R Performance's Avatar
Yes it is!!! it's awsome
Old Dec 3, 2008 | 09:58 PM
Invalid_User's Avatar
hmmmmmmmmm
Old Dec 4, 2008 | 05:54 AM
w0ady's Avatar
fgc moderator
is this tune done on a dyno?
Old Dec 4, 2008 | 08:30 AM
Yes, AWD Dyno. After we are finished we still like to take it around the block.
Old Dec 4, 2008 | 08:34 AM
iamericgee's Avatar
im in !
Old Dec 5, 2008 | 12:20 AM
_jb's Avatar
_jb
Photographer
This is a great opportunity, guys... Especially if you have a normally aspirated car...
Osiris Tuner Pro modifies the values directly in the OEM ECU... There is no map shifting like what happens with UTEC's and other piggybacks. This is the best method of tuning NA cars because the ECU learns towards the targets that are set by S&R while your car is on their dyno. You get a real time dyno tune that lasts without buying any Engine Management Hardware like a Haltech or FCon VPro.
Don't confuse Osiris Tuner Pro with the standard version of Osiris where UpRev creates maps from your list of mods. This is completely different.
If you have an NA VQ with breathing mods like plenums, or headers, or HFC's, or test pipes, or exhaust... you should seriously consider getting your car tuned.
Old Dec 5, 2008 | 06:08 AM
w0ady's Avatar
fgc moderator
^good info john.
Old Dec 5, 2008 | 08:29 AM
mdemonte's Avatar
Will the Osiris Tuner Pro work for an older VQ?
Old Dec 5, 2008 | 08:48 AM
iamericgee's Avatar
i need this badly ! i wanna be just as fast as jb !!
Old Dec 5, 2008 | 09:06 AM
Keep in mind that this also great for F/I. You will need to upgrade MAF Sensor.
Probably the most versatile performance mass air sensor on the market. Complete with the HPX software tool the possibilities are pretty much limitless.
Key Benefits
Capable of supporting over 1000WHP
Will never peg
Can be used in almost any intake system configuration
Great for blow thru or draw thru systems
Never needs re-calibrating
No more need for a conventional mass air sensor assembly, this sensor simply drops into your existing intake plumbing.
Small footprint allows for exceptional airflow
Every sensor is repeatable within O.E.M. spec
Software transfer-function generating tool included for using the HPX in different tubing.
Limited Lifetime Warranty
Old Dec 5, 2008 | 01:16 PM
ah i want so bad but no money.... lol
Old Dec 5, 2008 | 09:20 PM
AS007's Avatar
Put me down for this!
Old Dec 5, 2008 | 10:33 PM
D&G35's Avatar
where is the shop located??? i may be interested...not sure if my mods are worth doing it though..
