Need help installing satellite radio
Old Jul 13, 2009 | 09:42 PM
ARoss's Avatar
Question Need help installing satellite radio
This is on an 07 Sedan with Bose. I bought the factory kit from Grubbs but I can not figure out where to mount the receiver. I found the wiring harness under the rear deck on the drivers side, but the directions I have show mounting it to the back of the rear passenger seat. Is there another wiring harness?
I plugged everything in and it works. I even get a signal with the antenna on the rear deck behind the seats (I ran the wire through the child seat latch).
Anybody install one of these on an 07+ Sedan?
Thanks!
Old Jul 13, 2009 | 10:08 PM
Kidcane's Avatar
Dont know, on the coupe there is a harness in the trunk.
Old Jul 13, 2009 | 10:40 PM
Evil Wayzz's Avatar
satellites are like 300 feet wide how are you going to fit that in the Coupe?
Old Jul 13, 2009 | 10:50 PM
ishiftinheels's Avatar
Teh Redhead Moderator
Nope, never done it on an 07+ sedan lol... but I think you can mount it anywhere, it shouldn't matter. It usually comes with brackets to mount under the rear deck. If not, you could probably fabricate something...?
Old Jul 14, 2009 | 12:02 AM
Evil Wayzz's Avatar
Dude take it to orlando infiniti they will hook you up for the Cheap i had a problem also kinda and they only charged me 50 bucks to run the wires and hide them.
Old Jul 14, 2009 | 07:41 AM
ARoss's Avatar
The problem is where the directions show to mount the receiver in the trunk is not in the same location as the wiring harness.
Old Jul 14, 2009 | 09:28 AM
iamericgee's Avatar
im sure there is a diy on this site for that !
Old Jul 14, 2009 | 02:37 PM
ARoss's Avatar
I've searched this site top to bottom and I've found plenty of posts about installing it on coupes but nothing on an +07 Sedan.
Old Jul 14, 2009 | 02:53 PM
Sen's Avatar
Sen
Try g37 sites? The 07 sedan is the V36 chassis, right?
Old Jul 14, 2009 | 03:32 PM
ARoss's Avatar
Yes, they are the same chassis, but the G37's come standard with satellite radio. So no help there.
Old Jul 14, 2009 | 09:56 PM
Sen's Avatar
Sen
Ahh, okay. Ya learn something new everyday!
Old Jul 17, 2009 | 10:17 PM
ARoss's Avatar
Anybody else out there who installed satellite on an 07 Sedan?
Old Jul 27, 2009 | 02:14 PM
ARoss's Avatar
Just an update on this. I finally got the satellite radio installed and working. I bought an N-bus wiring harness extender at Brandon Nissan which allowed me enough length to plug everything in. I mounted the satellite tuner in the factory location which is under the rear passenger side trunk deck. The bracket was there and everything! I get pretty good reception with the antenna mounted on the rear deck, however, it does go out when under a lot of trees or in my garage.
Old Jul 27, 2009 | 04:27 PM
iamericgee's Avatar
Kool !!!
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 12, 2015 05:16 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Tom_P
Jul 24, 2015 04:05 PM
