Window Mods
Window Mods
hey guys
i ordered 10 window mods so i could have some for you guys if you dont win the raffle. they are the new ones with the eprom chip in them. who is interested in gettin one? also let me know if anyone wants the VDC memory mod cause i will have to order some of those.
thanks
thanks
Originally Posted by SFLG35
hey guys
thanks
thanks
i can you guys the window mods for $60 and will do the installing for you.
austin: im sure i can put it in for you at the meet.
the nav program i dont know much about. all i know is that it is a modified vdc memory mod that kevin did and put on his nav. it requires a lot of time to install it as well as solidering directly to the circuit board. aka something you would have to sign a waiver for, if im the one doin it.
also if anyone wants vdc memory mods let me know cause i only have one and will need to order somemore.
thanks
thanks
Originally Posted by G35Sean
Daniel,
What's an "eprom chip"? I have the old roll up mod. I had to reprogram my key codes when I got a new key fob now the doors won't lock when the car is started. I know it's easy to program but I can't remember how. Could you post or PM me with instructions? Thanks
Start the car and press the lock button on the key fob 3 times, one time each second for 3 seconds. The first time the doors will lock. The 2nd and 3rd times are finalizing the programming. Turn the car off, unlock the doors and open the door and then restart the car... doors should lock automatically.
![Wink](https://g35driver.com/forums/images/smilies/wink.gif)
Your factory key fob can roll the windows down just by holding the unlock button down. The only way to bring it up is by inserting your key into the car door or ignition. This mod will allow you to remotely roll up the windows by hitting the Lock button twice. You can vent the windows by pressing lock again while the windows are rolling up. Another feature is auto-locking the doors when the car is started, this function can be turned off.
