Window Mods
Old 03-13-2005, 04:56 PM
aznluder's Avatar
Florida G35 Club Premier Member
So the clifford alarm integrated nicely with the window mod from KP? That's pretty cool.
  #77
Old 03-13-2005, 05:20 PM
KPierson's Avatar
Please keep in mind that the KPtechnologies module is designed for OEM integration. It can be used with aftermarket alarms, but it actually will only complicate the install. On the G35 you only need an extended (-) trigger on the lock wire to raise the windows. So, if you have Aux channels of your alarm all you have to do is wire them to the lock/unlock wires and you'll have window up/down control.
I would be suspicious of any shop that charges over $20 to hook this up, and I am very suspicous of the 'windows raise when armed' feature, as that is NOT possible with the KPtech module. I wouldn't be suprised if the KPtech module is sitting in the installers toolbox right now!
Besides going up upon arm can you raise the windows in any other way?
  #78
Old 03-13-2005, 11:54 PM
Gman2004's Avatar
I will try to close the windows with out arming tomorrow and post my findings.
05-22-2022 09:26 AM
g.spot
05-09-2016 10:54 PM
BradMD_96
10-06-2015 09:31 AM
Learned Hand
10-01-2015 09:02 AM
RWDguy4238
09-30-2015 12:13 AM
Quick Reply: Window Mods
