My Car Is Broke.
Apr 28, 2005 | 01:36 PM
my cousin has an evo and i drove to the SUNCO, early afternoon we filled our tanks with 110 octane gas i had a quarter 93 octane left, i drove for 10 min on 95 the car shut off and did not turn back on why??? his car is perfectly fine, i just had it towed to broward infiniti.
Reply 0
Apr 28, 2005 | 01:38 PM
my cousin said that there was 6ft flames coming out of my exhaust for 1min this was 10 min before it shut off. his car flamed the whole way tobut is still running.
Reply 0
Apr 28, 2005 | 01:48 PM
will warranty cover ???
Reply 0
Apr 28, 2005 | 01:55 PM
Do you still have cats on ur car? If so, you probably clogged them up.
Reply 0
Apr 28, 2005 | 02:09 PM
Did you to check to see whether or not the 110 octane was a leaded gasoline? I've swung by a sunoco that had the same and almost got it prior to our 1st dyno day until I read the "leaded" fine print. Infiniti recomends unleaded gasoline. Hope everything goes well with your car.
Reply 0
Apr 28, 2005 | 03:05 PM
I just.........I just cant even bare to post a reply...............
Reply 0
Apr 28, 2005 | 03:43 PM
If you filled up with 110 octane you filled up with leaded, unleaded usually only has about a 100 or 103 octane. What probably happened was the lead killed the oxygen sensor and then the car started running really rich causing the flames out the tailpipe. The flames is unburnt fuel igniting in the exhaust. I hope infiniti doesn't find out you put leaded or they will charge you for the parts and labor. Good luck.
Reply 0
Apr 28, 2005 | 04:15 PM
may car has oem exhaust, got a call fron broward infiniti, he says that my fuel pump has failed and there is a problem with the 02 sensor, he says its covered under warranty. i got lucky.
Reply 0
Apr 28, 2005 | 04:21 PM
car should be fixed by this afternoon or tomorrow morning they have all the parts in stock and it was a slow day, so they have 2 guyz working on my car.
Reply 0
Apr 28, 2005 | 06:00 PM
wow..........what color is your cousins evo??
Reply 0
Apr 28, 2005 | 06:15 PM
Next time, try running diesel. It will just kill the entire engine instead of a silly fuel pump and O2 sensors.
Reply 0
Apr 28, 2005 | 07:52 PM
my cuz has a red evo, intake exhaust, bov, dress up kits, eye lids, hid boost, and i still am half a car length away in a race !
Reply 0
Apr 28, 2005 | 07:53 PM
Quote: Next time, try running diesel. It will just kill the entire engine instead of a silly fuel pump and O2 sensors.
i was told that our cars could take 110 octane, but i might have needed a test pipe.
should be ready in the morning.
Reply 0
Apr 28, 2005 | 08:42 PM
Quote: i was told that our cars could take 110 octane, but i might have needed a test pipe.
WRONG!
The guys above have it right- if it's not UNLEADED FUEL it's not good (or legal) to run in your car. Consider yourself rather lucky to have "slipped under the radar" on this one- I'm still baffled that fuel quality wasn't checked during diagnosis on this problem.
Reply 0
Apr 28, 2005 | 08:55 PM
i have seen that evo before
Reply 0
