F/I SEDANS.raise your hands!
Old Jan 7, 2008 | 01:59 PM
  #31
ttrank's Avatar
Grocery getter
Originally Posted by sliderg35
I had it dynoed on a Dyno-Dynamics setup. It came in at 328 HP with the stock fuel pump. I have since replaced the pump with a Walbro and fixed the fuel but I haven't re-dynoed. The tuners here suck. I figure I'm making at 20-40 hp more than before. I'm doing it all myself now until I can take a trip to CA to find someone who knows what they are doing.
Did you make any changes to the tune for your new fuel pump?
Old Jan 7, 2008 | 02:16 PM
  #32
sliderg35's Avatar
I have been waiting for my A/F to be connected to the E-Manage so I could get a good graph. It's all in now and seems to be working well, but the A/F is still looking a little lean on the top end. I have already maxed out the injectors so I won't be able to get any more fuel unless I switch to bigger ones. I'm not sure why this would be happening because I have seen others getting over 400 hp with the 440s. My engine is a little different from the norm here because it is a very early 03 with the strange ECU plug.
Old Jan 7, 2008 | 03:34 PM
  #33
FI'ed G's Avatar
Do you have a 440? I'm tuned at around 70F and my injector (440c) are around 80% Duty Cycle at 8psi. At weather below 32deg F, I have Utec add 17% Fuel just to compensate with the Colder Air to get my A/F in the low 11's and at 6psi and 6000rpm my injectors are already 100% Duty Cycle. I can still run at 8psi but I have to shift around 5500rpm. You are in Canada so I think in colder weather that you need a little bigger Injector to compensate with the drastic change in Temp.
Old Jan 7, 2008 | 03:57 PM
  #34
G-Mony's Avatar
I had 440s on it was running real lean. Maybe its different cos we're TT instead others have SC? GTM Upgraded me to 560cc Denso injectors. Any downside to go bigger injectors?? It doesnt cost much.
Old Jan 7, 2008 | 04:59 PM
  #35
sliderg35's Avatar
Do the Denso Injectors have the same connector as the 440s supplied with the Greddy kit? Where did you get them?
Old Jan 7, 2008 | 05:11 PM
  #36
ttrank's Avatar
Grocery getter
I have 440's that are about 85% in the cold weather here.
Old Jan 7, 2008 | 05:23 PM
  #37
FI'ed G's Avatar
what is cold weather in Phoenix That is Early Spring to us...lol j/k
Old Jan 7, 2008 | 05:29 PM
  #38
ttrank's Avatar
Grocery getter
More like early summer!
Today it's ~50 and rain. It did go below 32 for a couple nights and killed a bunch of my plants in the back yard!
Old Jan 12, 2008 | 12:51 PM
  #39
QuadCam's Avatar
1. type of f/i....s/c, s/t, tt, nitrous.....and manufacturer
NX nitrous....to.....TN ST...to.........GReddy TT
2. stock internals.....Yes/ if no, what did you beef up?
Stock for now......but built motor is coming shortly.
3. stock exhaust.....Yes/ if no, what do you have?
Custom 2.5" True Dual with 5 Magnaflow mufflers
4. flashed ecu or stand alone? if stand alone/piggyback, what'u got?
UTEC
5. hp/tq gained and running at what psi?
400/400 @ 9 psi
6. WOULD YOU do it again? post your feelings away, the good, the bad and the ugly.....
Absolutely!!!
Old Jan 13, 2008 | 03:59 PM
  #40
SouthernG35's Avatar
Sorry to highjack but what gauges (manufacturer) and where are they placed in you guys setup. My sedan is at Performance Factory right now and I was wondering what gauges I was going to install. I am thinking about the Autometer Nexus wideband, oil pressure and boost.
Old Jan 13, 2008 | 04:50 PM
  #41
ttrank's Avatar
Grocery getter
Right now I have the Zeitronix (A/F, boost and egt). I am taking that out in a month or so because I now have AutoMeter Nexus (A/F, boost, egt, oil press, fuel press and oil temp).
Old Jan 13, 2008 | 09:12 PM
  #42
QuadCam's Avatar
Did you buy Ken's setup when he was parting out his G?
Old Jan 14, 2008 | 01:34 AM
  #43
ttrank's Avatar
Grocery getter
Yep. That is where I got half of them and he was local so I met him down in Tucson to get the parts. That @ss is getting a GTR!!!
Old Jan 14, 2008 | 09:30 AM
  #44
QuadCam's Avatar
what's he driving in the mean time? the GTR won't hit showrooms for about 8-9 months.
Old Jan 14, 2008 | 11:35 AM
  #45
ttrank's Avatar
Grocery getter
He said something cheap for now. I don't remember what it was.
I got his controller, oil press, fuel press and boost gauges then ordered the A/F, EGT and oil temp from one of the vendors because they beat every other price I could find. The A/F is on backorder for a at least a few weeks but I'll have the other two this week so I can get started on the 3-pod for above the ac/heater display. That will take me a while anyway.
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
doakley92
Sep 25, 2015 12:58 PM
