VDC, SLIP, BREAK Light Issues???
Old Jul 28, 2006 | 10:39 AM
FL-G35's Avatar
Ok, This has just started to happen to me after I put the charger on. The first time this happened was at the dragstrip. As I was running down the track, my slip light came on and sayed on along with my break light (the light that comes on when you push e-brake down). At first i thought it was because I lost traction as I was running down the track. After the run I turned off the car and it reset and didn't come back on.
Recently driving normally without turning vdc off, I went WOT and the VDC, SLIP and BREAK lights came on all over again. I figured I must have freaked the computer out since I have the Stillen S/C on there. More recently it has been happening more often. They don't turn of until I turn off the car to reset everything.
Has this happened to anyone that is N/A or F/I??
Old Jul 28, 2006 | 11:42 AM
NJlakeshoreG's Avatar
you either need brake fluid or brakes....same thing just happened 2 me....i thi nk it was just a coincedence...
Old Jul 28, 2006 | 11:45 AM
FL-G35's Avatar
Wow, simple enough. Thanks. So just that triggers all of the lights. Go figure, I would have thought just the breaklight would have come on.
Old Jul 28, 2006 | 01:08 PM
yea...i just asked the dealer this morning actually...your welcome...
Old Jul 30, 2006 | 02:14 PM
ericinmia's Avatar
lol yeah this has happened to me more times than i can count in the 3 years i have had the G... at least a few times a year, when i wear the brakes down to nothing/brake fluid low.
Just fyi... unlike turning VDC off, which simply raises the levels at which the computer kicks in to save your '***', when the SLIP and VDC OFF are on permanently that means that the emergency systems are TURNED OFF.
You can have a lot more fun when they are like this... Be careful.
There are artificial ways to trick the computer into turning them off also..
BTW... mine have been on for a couple weeks, brakes are so low that the pistons on the calipers are extended very far; hence the brake fluid in the reservoir is low.
-Eric
Old Jul 31, 2006 | 09:20 AM
FL-G35's Avatar
-Eric
Eric,
What are those artifficial ways you mention. All I have done is turned off the VDC at the track. I figured if that light stayed on that it is OFF PERIOD. I was talking with a Lexus IS 350 guy and he was telling me what he had to do and it reminded me of old nintendo days...up up down down left right blaa blaa blaa. It was crazy what he had to do. We don't have to do the same do we?
Tracy
Old Jul 31, 2006 | 09:35 AM
superchargedg's Avatar
tracy mine did this also even before i put the s/c on.did you take the car back in for the recall of the brake interlock switch.it was a recall of the early 03,s and its free.
Old Jul 31, 2006 | 01:15 PM
FL-G35's Avatar
When did they do that recall, Keith?
Old Aug 1, 2006 | 08:30 AM
that was back in late 03 and i didnt do anything about it.then in early 05 those lights would come on and go off,so i took it in for them to check out and it turned out to be the recall.they have never come on again.youll have t look up the old recall notices to find the number.
Old Aug 1, 2006 | 10:33 AM
FL-G35's Avatar
I'll check it out, Thanks. I put more fluid in (it was a little low) and lights went off. I think it is time for a break check. Thanks everyone for your help.
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
Wayne9011
Aug 17, 2015 01:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
