Running 400whp on stock internals safe?
Old Sep 1, 2006 | 03:26 AM
bigkrnxboi's Avatar
I am going to run 400whp give or take 4-5whp. Can our rev up engines take this? Am i safe? How long will my engine last? For all those running stock internals with aps st, tell me
1. how much whp/tqe u are running
2. built or stock internals
3. psi
4. where u get ur tunes
5. how many miles u have run on the engine w/ turbo, any problems?
THANK U!
Old Sep 1, 2006 | 04:39 AM
GTT's Avatar
GTT
G35 Twin Turbo
Search
Old Sep 1, 2006 | 08:22 AM
Brando's Avatar
Cool
No....Nothing's "Safe".
You pay your money and take your chances.
I personally would never install a turbo on the VQ without building the motor.
A SC is a little better because of the linear torque curve.
Old Sep 1, 2006 | 09:25 AM
exagorazo's Avatar
If you don't build the engine, it's just a matter of time before it blows. Then you'll be looking at a $10K repair job and you will be nowhere.
Save yourself money and grief and put $5K (at least) into the engine when you go FI - or stay N/A.
Old Sep 1, 2006 | 10:05 AM
BrianlG35C's Avatar
Ohio G Club Member
Amen!!
Old Sep 1, 2006 | 10:15 AM
ma_sha1's Avatar
Neither Engine nor tranny is safe at 400 whp, ~480 Flywheel hp.
I am doing FI on stock internals but I am only doing 300 whp
Old Sep 1, 2006 | 01:50 PM
Audible Mayhem's Avatar
there are tons of people who run 400 hp on stock motors. 400 is just about the point where you start really straining the motors stock potential. one missed gear or over rev and you will be done. i know people who have lasted a year and lots of miles with 400 and i know people who have blown engine in under a month.
good luck either way
Old Sep 1, 2006 | 01:56 PM
Mr_pharmD's Avatar
Very true. If u know u are going to put a lot of abuse on the engine then just upgrade your piston and rods and keep on beatting it to death at 400-500hp. But if u take care of it then it will last. It also depends on your tunning. If u running pretty lean up top then it will blow faster.
Old Sep 1, 2006 | 03:03 PM
its just like when people ask me, "how long will my motor last if i have nitrous??"
well. it all depends on how you use it, if you have 400 hp on a stock block and dont rev it to the rev limiter every gear and baby it for the most part, it could last forever..
Old Sep 1, 2006 | 03:49 PM
BrianlG35C's Avatar
Ohio G Club Member
And what's the fun of that?
Old Sep 1, 2006 | 03:51 PM
imalazeeass's Avatar
when u say overrev, are u talking about just hitting the redline? So for those that drive the car hard, when would they normally shift with such high HP? I find it hard to avoid the rev limiter when driving really hard or perhaps when you're racing someone.
Old Sep 1, 2006 | 03:53 PM
2006_G_coupe's Avatar
+1,000
Old Sep 1, 2006 | 05:14 PM
Mr_pharmD's Avatar
why would u rev your car that hi anyway? NA peak pw is 6400 rpm so waiting until redline is making u go slower.
The only reason why I see ppl are bouncing off the revlimiter is if the turbo is at full boost it can cause the acceleration to increase soo fast that one doesn't have the time to shift before red line.
Old Sep 1, 2006 | 08:14 PM
DeatschWerks's Avatar
That is just not true. Tranny is more than up to the task for far more power than that, and with a quality set up and good tune 400whp is perfectly fine.
No reason at all to build a motor for 300whp. None at all.
