Vortech Installed!!!
Old Sep 18, 2006 | 08:50 PM
  #31
IlirG's Avatar
Just to get an idea of the Power Curve. Car is running beautiful right now.
Old Sep 18, 2006 | 09:11 PM
  #32
freezeg35c's Avatar
Originally Posted by IlirG
It is a little low? But for now the car is safely tuned, and feels great, so I will not complain. In a couple of weeks I will be putting on the 3.12 pulley, upgrading the injectors, and the fuel pump, an getting it tuned once again.
Doh, did what i did, should have done the 3.12 right off the hop.
What size injectors you going with. I dont think you can scale back
anything bigger than 380's, but booger would know more. I think
you have to adjust fuel cells in the vacuum side so you dont run
rough and rich.
Old Sep 18, 2006 | 09:21 PM
  #33
IlirG's Avatar
rough and rich.
Yep, should have. But it will be nice to see what the HP will jump to once I throw the 3.12 on there, put 440 injectors, and get it tuned to be a little bit meaner lol. I am curious as to what is causing the low numbers though, I'm going to lose the Spacer as that might be a possibility...
Old Sep 19, 2006 | 01:31 AM
  #34
Mr_pharmD's Avatar
That dip in pw up top is wierd. I too have it for my vortech dyno. What gear did u dyno it and at wat psi? If u are thinking about upgrading to the 3.12 pulley, u wont need the 440cc. U can stay with 380cc and u wont have to reflash the ecu bc there's no way u are going to make over 400hp with the 3.12 pulley.
Old Sep 19, 2006 | 01:39 AM
  #35
Dan_K's Avatar
Why would the plenum spacer rob you of hp? I would think it would increase top end hp, but decrease boost.
Old Sep 19, 2006 | 01:49 AM
  #36
Deang35c6's Avatar
hmmm, looks funny. Did they give you the boost levels you made you power at? You should be able to see your A/F too, so you can see how much power is being made from 1 to 8 psi. I think you're not getting a full 8 psi. The newer belts tend to slip more. I made 340 rwhp on a DD with 8 psi and Crawford Cast with a very conservative tune. I had 79k miles when I installed the SC.
Old Sep 19, 2006 | 09:28 AM
  #37
IlirG's Avatar
Thanks for the info!
Old Sep 19, 2006 | 09:29 AM
  #38
IlirG's Avatar
I dont know why it would, but it's worth taking off and dynoing with out it just to make sure? Unless some one already has tried this and would like to chime in?
Old Sep 19, 2006 | 09:37 AM
  #39
IlirG's Avatar
Well as for the belt, I have the 93.5 Gates belt on there so I dont think that would be causing me to loose psi. I was not there for the dyno, kel did you guys check where I was at with boost? Well my Walbro 255 just came in, Pulley is on its way, so by next week she will be getting everything on and dynoed again. And she is pulling just beautifully right now, I am very very pleased.
P.S. Do you guys kow if the Gates 93.5 will work with the 3.12 Pulley? Thanks
Old Sep 19, 2006 | 09:43 AM
  #40
FI'ed G's Avatar
I'm more interested on your TQ, do you have a graph also AF will be nice too.
Old Sep 19, 2006 | 03:50 PM
  #41
Dan_K's Avatar
No, you need to get a smaller belt. Not sure on the size though. Did you just dyno your car or was it tuned as well?
Old Sep 19, 2006 | 04:17 PM
  #42
kzanard's Avatar
you need the 93.0 belt for the 3.12 pulley.
Old Sep 19, 2006 | 04:24 PM
  #43
IlirG's Avatar
Thumbs up
Thanks! Actually I DO have the 93 belt right now on the 3.33 pulley, so Im good to go!
Old Sep 20, 2006 | 04:14 AM
  #44
jclit's Avatar
Damn something is wrong, 310 hp on a vortech, i think thats the lowest ive heard. You imagine with 60 more hp that youre suppose to have, youll be real happy.
Old Sep 20, 2006 | 09:51 AM
  #45
IlirG's Avatar
Exactly, I'm like if this is what 312 is like, I cant wait to figure out whats up and feel what 350-380 is like.
