vortech belt noise...
Old Sep 30, 2006 | 06:14 PM
TwilightBLUES's Avatar
well i got the 93.5 gates on not to long ago and had it tighted after a few drives. Now there is a very low-tone squealing/ ringing noise coming from the belt/pulley. Its starting to drive me nuts, had it at the dealership for new brakes and their tech stated blower wasn't getting enough oil/lubricant???
very confused need sum helpppppp!
Old Sep 30, 2006 | 06:43 PM
superchargedg's Avatar
unlucky for you it sounds like the normal vortech sound,which sucks.
Old Sep 30, 2006 | 07:26 PM
to be honest, this sound happend before as well, but would go away after a minute after start up. any suggestions, anyone else find a way to stop this noise????
Old Sep 30, 2006 | 07:42 PM
Mr_pharmD's Avatar
u sure its the belt or many an idler pulley going bad. I replaced all 3 idler pulley and my noise went away.
Old Sep 30, 2006 | 07:53 PM
hmmm it could be, by any chance were you not getting the boost you should have been before you changed the ilder?
Old Oct 6, 2006 | 07:03 AM
Dan_K's Avatar
Could you elaborate on the noise and where you got the pulley's?
Old Oct 6, 2006 | 12:18 PM
Mr_pharmD's Avatar
the bracket has 3 idler pulleys + 1 jackshaft pulley. The middle idler pulley wasnt spinning freely so it was making a really loud noise but as u let it warm up the noise would get better but still there. My installer told me the bearings went bad so that was the reason for the noise. We finally replaced all 3 just incase if it did happens again or there was another one almost going bad. They are around 25-30 dollars each and u can order them from vortech or even at napa or autoparts store. I read somewhere someone ordered one from summitracing. GL
Old Oct 6, 2006 | 12:32 PM
thanks Mr. pharmD, looks like i will be changing them afterall.
Old Oct 6, 2006 | 02:22 PM
ISMSOLUTIONS's Avatar
You can take a piece of wood and hold it against your ear on one end, and the pulley bracket, near the idlers on the other. You will hear the noise, if they exist, at each idler. Also, you can hold against the blower as well to see if you have noise there that shouldn't be...
Broom sticks, cut short, work well.
Rick
Old Oct 6, 2006 | 05:13 PM
G35BASTARD's Avatar
Once replaced, post back and let us know if that fixed your problem.
Old Oct 6, 2006 | 05:22 PM
Hollywood G35's Avatar
I used to have the Vortech before going Turbo. This may not be the problem, but I had a squealing noise at low rpm that I thought was coming from the blower or a pulley. We swapped out pulleys. It ended up being the BOV. Air was escaping and sounded like a squeal. A small adjustment and the noise was gone.
Not sure if this is the same problem but worth a shot.
Old Oct 8, 2006 | 06:07 AM
Dan_K's Avatar
Did the sound occur on every gear? I have a small squeal on take off in first and second. What did you do to the BOV?
Old Oct 8, 2006 | 08:36 AM
^^^Ya - it happened in every gear - low rpm. There is a set screw adjustment on the recirculating valve. I adjusted it slightly and the noise went away completely.
Old Oct 8, 2006 | 12:18 PM
Mr_pharmD's Avatar
just buy a filter for the bypass valve. It reduced the noise by 60% and allowed me to be able to hear my exhaust now. One bad thing is it reduces the noise soo well that u dont really hear the loud psssssssssssssssssssss after u decelerate after shifting.
Old Oct 8, 2006 | 12:20 PM
I've got the filter on mine, and it really only reduiced the sound by MAYBE 20% - it's still does it's thing...but a little subdued...
Rick
