Dual gauge pods up & Running wideband A/F Ratio & Transmission Temp.
Old Nov 5, 2006 | 02:14 PM
ma_sha1's Avatar
I decide to install the wideband AFR & Transmission Pods before the S/C job,
so that I would know a reference point & see what changes on AFR &
Transmission T. the the S/C would make.
They are mounted on the pilar but it's more stealth than tipical Pilar Pods,
This location is ideal for viewing while driving.
ARF right now runs between 13.7-14.3 normal driving & ~12.6 at WOT
Transmission Temp. ~130 after 20min winter driving.
Pic 2: You can not see it from the side at all, remain stealth:
Pic 3: You can see it from the front, but it's incely blended in with the black dash.
Old Nov 5, 2006 | 02:48 PM
chimmike's Avatar
you do plan on running a boost gauge, right?
Old Nov 5, 2006 | 02:55 PM
Meatshackle's Avatar
Deep Sea Moderator
Good question. AFR is very important but you could have 11:1 and overboosting without even knowing it.
Old Nov 5, 2006 | 03:11 PM
GTT's Avatar
GTT
G35 Twin Turbo
did you drill the cats to install the AFR gauge ?
Old Nov 5, 2006 | 04:21 PM
rookie's Avatar
12.6 WOT sounds a little lean to me, probably makes decent power but dangerous. Where's the sensor located?
Old Nov 5, 2006 | 05:09 PM
ttrank's Avatar
Grocery getter
If that's 12.6 before the cat it's pretty lean. I'm ~11.3-11.6 at WOT.
Old Nov 5, 2006 | 05:39 PM
chimmike's Avatar
he's not supercharged yet, so 12.6 AFR either way at WOT isn't lean.
Old Nov 6, 2006 | 12:39 AM
rookie's Avatar
Ooops I didn't notice this is pre HKS SC install. Where is the temp sensor located for the transmission? Pre or post cooler?
Old Nov 6, 2006 | 02:10 PM
ma_sha1's Avatar
The dealer found a hole at the rear end of the transmission, so he screwed the sensor into it. The hole had a nut on it before, that must be meant for sensors.
The sensor stick right into the transmission, so better than splicing it inline either before or after the cooler.
Old Nov 8, 2006 | 07:49 PM
QuadCam's Avatar
where did you get the pillar pod for a sedan?
Old Nov 8, 2006 | 10:18 PM
Dan_K's Avatar
Ya, I am interested in the pod as well. Looks a lot better than the other ones out there.
Old Nov 9, 2006 | 01:29 PM
ma_sha1's Avatar
$10 Universal Dual Pod I got on ebay.
It says it's for g35 coupe & a bunch other cars.
Heat over stove to make it soft so you can form/trim for your pilar shape.
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
saskicker32
Aug 11, 2015 02:12 PM
newg37
Jul 26, 2015 09:32 AM
