I just Noticed..
Old Nov 5, 2006 | 07:52 PM
TwilightBLUES's Avatar
I just Noticed..
Is it time for a new belt or is that normal? Just a bit concerned!
To be honest i dont even know from what pulley this belt is. Can anyone Help with type n size? thanks guys inadvance
Old Nov 5, 2006 | 08:10 PM
pp7's Avatar
pp7
Yea I'm nearly at 45k miles and am wondering if I need a new belt too? Do I?
Old Nov 5, 2006 | 08:19 PM
sentry65's Avatar
probably
Old Nov 5, 2006 | 08:22 PM
gary c's Avatar
Fuzzy belt..............?
If it looks like Twi's belt don't go the grocery store
until it's replaced.......just to be safe of course.
Old Nov 5, 2006 | 08:33 PM
mokc's Avatar
That look like the AC belt. I had to replace mine at about 50K something. It was starting to crack.
Old Nov 5, 2006 | 10:03 PM
G352NV's Avatar
Never enough
Odds are the intake charge pipe is installed wrong. Check it, then replace belt.
Old Nov 5, 2006 | 11:34 PM
Deang35c6's Avatar
something is rubbing...
Old Nov 5, 2006 | 11:45 PM
ttrank's Avatar
Grocery getter
That's the A/C belt. It may just be time for a change but check the path before you put on a new one.
Old Nov 6, 2006 | 12:15 AM
Triji's Avatar
You are rubbing on something in there... Use your hand (engine off) and follow the belt around, it might be rubbing on a clamp in there somewhere.
Old Nov 6, 2006 | 12:18 AM
G352NV's Avatar
Never enough
Pull the intake charge pipe off. This is the one that rund near the frame rail. Turn it around and bolt it back up. Problem solved.
Old Nov 6, 2006 | 02:02 PM
cool thanks guys, first thing on my agenda as of today!,
by any chance does anyone know if gates makes on for our cars? i could only find the goodyear gaterback.
Old Nov 6, 2006 | 03:29 PM
denverinfiniti's Avatar
Yeah looks like the pipe is definately rubbing the belt. You guys are lucky if your belts are lasting past 40K. We replace belts here at work around 30k
Old Nov 6, 2006 | 04:26 PM
Dan_K's Avatar
Just get the oem belt for the a/c. Doesn't really need a good one since it's not under much stress.
Old Nov 6, 2006 | 05:44 PM
Yea either way i got the Gates belt on the way, prices were the same.
radioking
Jan 6, 2014 10:28 PM
ctk519
Apr 9, 2011 02:15 AM
Mosi
Aug 28, 2007 07:42 AM
CarNutz
Mar 2, 2007 11:13 AM
