Tn st cat question......
Old Jan 11, 2007 | 08:09 PM
klg35's Avatar
any know offhand of cat similiar to the cat that comes with this kit?
bought used kit w/o the cat and was thinking about welding one on the pipe...........so, with cat on there, maybe lose 10hp or so?
Old Jan 11, 2007 | 10:42 PM
G-Mann's Avatar
it doesnt come "with a cat". the tn kit thats the "w/ cat" just means its ganna use the stock cat. the tn kit thats "w/ out cat or no cat" means it bypasses the stock cat. and yea around 10-15hp loss/gain w/ the cats
Old Jan 11, 2007 | 10:50 PM
2slo2bfurious's Avatar
....both kits replace the stock cats, theres many brands of cats that you can weld on the second downpipe. Magnaflow makes a great well priced one, or you can just call up tn and order the second down pipe with a cat although it might be more pricey that way.
Old Jan 12, 2007 | 12:32 PM
klg35's Avatar
will check out manaflow........thanks.
Old Jan 12, 2007 | 12:41 PM
gary c's Avatar
Converter question...............
Magnaflow doesn't make a converter for our Infiniti G35s! However they do
make a universal fit converter that might work. Try Chris at Magnaflow he
knows his exhaust systems.
Old Jan 12, 2007 | 12:43 PM
Calvin's Avatar
Overglorified Altima
i'm not sure but i think FI uses magnaflow cats
Old Jan 12, 2007 | 04:35 PM
G-Mann's Avatar
im using stock cat on tn kit
Old Jan 12, 2007 | 11:19 PM
Yup! The universal magnaflow cats are what I was referring to.... it will help you loose the smell, not too sure about the sniffer test though.
Not to be a smartass, I hope you mean you are using a STOCK TN CAT in other words a TN ST kit that comes with a cat, and not meaning a stock nissan/infiniti cat on your tn kit, since the TN ST kit regardless of model for the z or g, removes the stock nissan/infiniti catalytic converters....
Seems to me this is a common misconception about all the available ST kits for the Z and G about parts of the exhaust that they replace....
Straight out of the TN kit instructions....
Please point out where these stock cats fit into the first picture.
Old Jan 13, 2007 | 01:22 AM
G-Mann's Avatar
owell looked like the stock cat to me
seagrasser
May 3, 2022 09:43 AM
Crisci33
Jun 29, 2017 08:31 AM
magnetism80
Jan 27, 2016 12:57 PM
NJ6MT
Oct 9, 2015 05:02 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
