Stillen SC and FCON
Old Feb 18, 2007 | 05:15 PM
SAM@GTM's Avatar
Originally Posted by rookie
Not to say the FCON is a waste of money but on a Stillen blower? Jesus, talk about overkill. If you were to move to something like a FCON/UTEC why even consider keeping the 7th injector?
You can install a hks FCON IS for the price of the uteck ,keeping the 7th injector is a must if we steel going to run stock injectors ,meaning no fuel system upgrade
Old Feb 18, 2007 | 05:21 PM
rookie's Avatar
For 350hp why not just upgrade the injectors? Don't the Vortech/Procharger guys run this way? What I'm kind of getting at is dumping more and more into the Stillen set up is hard to swallow no matter which way you look at it. Getting a better EM than leads to other inefficiencies in the Stillen set up. The heat exchanger thing will be the next thing to get in the way and than?
Not saying you're not offering the right solutions, but there is a wall and it will get to be a frustrating and expensive path.
Old Feb 18, 2007 | 07:08 PM
mokc's Avatar
Actually i'm seriously considering upgrading the injectors. It will make life much easier tuning wise. However, there are a few things that are holding me back in doing this...
1) As you know passing smog here in CA is a must in keeping those OEM injectors. Not that a stg IV will pass, but i think I would have a better chance with the OEM injectors in place.
2) As you mentioned, i spent way to much money already, in addition to that, i hesitate to remove the SC since it has its own upper and lower plenum. It would be a lot of work to get to those injectors.
I'm just looking for a simple solution if there is such a thing. I've seen 2 stg IV go up in smoke already and i dont want to be the next. And the bad thing about it is, I can hear it ping. It is not a subtle ping, but loud enough to scare anyone when you get on it. I think it is a matter of time before it the engine goes, just trying to do some prevenative "medicine"!!
Old Feb 18, 2007 | 07:24 PM
rookie's Avatar
What year is your car? I'm fairly certain 03+ don't need smog for 6 years as long as the ownership doesn't change in the first 4 years I think. I'll search it up but I found it googling before.
I know of a few that have done their own installs so it can't be too hard to take the blower assembly off.
Not trying to deter you in anyway. Buying it thru Stillen, and having them do the install is expensive I've been there. Have you tried a different fuel? Put in some 100 and see if the pinging goes away.
Old Feb 19, 2007 | 12:55 AM
mokc's Avatar
I have an 03, so this is my 4th year. Will need to smog in 2 years.
I won't attempt to remove the blower on my own. I imagine it probably isn't to bad, but there is no way i can attempt it, let alone install a return fuel system.
Stillen is kind of picky in what they install, and yes they are a bit pricey. But anything that is not smog complient, they will not install. I have tried the 100 octane stuff, and the car ran better with less pinging, but again, i hate to keep paying $6 or $7 a gallon for that stuff. I honest think i just need a good tune.
Old Feb 19, 2007 | 01:06 AM
rookie's Avatar
I have a friend that is running the stage 4 and he went down to Stillen and they supposedly did tune his box. The com port is on the inside opposed to the outside of the regualr Split second box.
I have the cipher program, not sure if you want to try a -2 on the timing? Weird you still ping on 100.
Old Feb 23, 2007 | 02:47 PM
ttrank's Avatar
Grocery getter
From what I know if you want to mess with the tune on the SS box you have to start a new one. The existing one can't be modified without a password.
Old Feb 23, 2007 | 08:51 PM
superchargedg's Avatar
hey tim how are the twins treating you,im thinking of going that route as well.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
hawaiian5
Sep 20, 2015 07:12 PM
