Coming Soon 3.9L + 5AT + TT + Zex
Old May 7, 2007 | 01:54 PM
  #31
b00stedjustin's Avatar
can the AT handle that much power? I'm guessing you will be making in the 500 range right?
Old May 7, 2007 | 08:18 PM
  #32
minus500's Avatar
Originally Posted by ttrank
Who did the conversion for you? SFR? How much was it?
I was looking at the 20G upgrade that SGP does and it would be nice to have options.
No, it was turbochargers.com. They're in TX and they have a good reputation. I believe their 06-1 upgrade is also several hundred $ cheaper than the 20G your speaking of.
Old May 7, 2007 | 08:19 PM
  #33
minus500's Avatar
Its a fully built SFR auto. It is supposed to support 1000whp. I'd like to go beyond 500whp but we'll see.
Old May 7, 2007 | 08:51 PM
  #34
ttrank's Avatar
Grocery getter
Thank you.
Old May 7, 2007 | 11:17 PM
  #35
minus500's Avatar
Thank you.
Go for it. Lets see what they do here.
Old May 12, 2007 | 06:15 PM
  #36
booger's Avatar
Hows the project going ? John getting things done in a timely manner ?
Old May 12, 2007 | 07:08 PM
  #37
EricIsKlumzyee's Avatar
^ Panda.. incrasing displacment is easyer with a stroker kit but it also adds ALOT more wear on the cylinder walls.. the angle of the rods between the crank and pistons are much more extreme then an engine not stroked.. so actually alot more R&D has to go through.. cause really tho.. more then half of us would NOT buy a G35 if we knew nissans will break down at 100k..
Will do. I'm actually kinda curious myself. In addition to better flow, they should also lower shaft speeds in turn making them a bit more reliable. Thats just my theory but, someone who has a complete understanding could validate that.
cam shaft speed? rpm? that'll be up to the tunner as i do not know the specs of your cam.. you're jsut going to go with whats ideal for your cam specs.. i would (pretty sure you did since you already did valves) upgrade the valve springs and shims.. this will allow your valves to SLAM shut keeping your boost in and eliminate cam float at high rpms.. and it also sounds bad *** at idle..
you'll do fine.. sounds like you're with a great performance shop that knows what their doing.. good luck =) post dyno seets as we're all interested in seeing your curve =)
Old May 12, 2007 | 11:27 PM
  #38
ttrank's Avatar
Grocery getter
I hope to soon.
Old May 13, 2007 | 04:48 AM
  #39
GTT's Avatar
GTT
G35 Twin Turbo
sexy project, why not going with Nirtous express. As i know it's better than ZEX.
Old May 22, 2007 | 02:21 PM
  #40
rookie's Avatar
Did you get your G back yet?
Old May 22, 2007 | 03:46 PM
  #41
Is this still going to be a street car or a drag car?
Old May 22, 2007 | 03:48 PM
  #42
Originally Posted by Chrlesmd
That's typically how Nissan increases power, by stroking the displacement out rather than designing a new engine. I'm pretty sure that's what they did with the 3.0 L...they stroked it out to 3.5L.
doubtfull...... for the new coupe yes, but they changed a hell of a lot of other things as well.
Old May 24, 2007 | 06:58 PM
  #43
minus500's Avatar
It was already on the car but, one system is esentially the same as the next...I think. I'm using the NX maximizer as soon as I can figure it outLOL.
Old May 24, 2007 | 06:59 PM
  #44
minus500's Avatar
Its on it's way to Altered for the FCon and 3" exhaust. Motor break-in numbers soon.
Old May 24, 2007 | 07:02 PM
  #45
minus500's Avatar
Full interior, stereo, sub, 20" wheel, DVD monitor street car.
