cold weather and vortech sc
Old Dec 14, 2003 | 09:56 PM
booger's Avatar
Has anyone found out about vortech and cold weather ? Someone said that the oil needs to be above 32 degree to run the vortech...is this tue ? And does the same apply to Prochargers sc. too ? I live in Nebraska and it gets dam cold...not going to drive it much this winter but dont want to be stuck with only one car and 2 people to drive it....Thanks
Old Dec 15, 2003 | 04:23 PM
zimbo's Avatar
Re: cold weather and vortech sc
I'll look into this. Since the Vortech uses the same oil as your engine it seems to me that it would have fewer temperature-related problems than the ATI--but what do I know.
All I know is that I drove my sedan with its newly installed Vortech supercharger three hours this morning in cold weather (well, cold for North Carolina which isn't saying much) and had no issues.
However... If I lived in Nebraska, I would keep the car in a garage and drive slowly while the car warmed up so as not to be boosting until everything got up to operating temps.
--Steve
Old Dec 16, 2003 | 08:00 PM
booger's Avatar
I do keep the car in the garage when Im at home...no problem there...its when I go some place and the car has to sit for a few hours in the cold that Im thniking of. Thx for the reply
Old Dec 17, 2003 | 12:04 PM
Q45tech's Avatar
Since the usual failure mode of superchargers is bearing wear. For the absolute maximum bearing life it is important that clean and correct oil temperature be maintained.
The ideal oil temperature is 180F, one would use premium synthetic oils to help extend life and change them every 90 days............a sump heater and temp sensor on the return line would give you lots of info.
G35Rican
Jul 31, 2024 01:37 AM
Freeman186
Sep 6, 2023 10:07 AM
seagrasser
May 3, 2022 09:43 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
