greddy tt install question
Old Apr 7, 2007 | 03:36 PM
alan21's Avatar
hey guys i am 90% done with my greddy tt install i just need some help for those of you who have installed it yourselves. I am installing it in the car.how did you tighten the outer bolt on the wastegate where it bolts to the down pipe adapter. Its the only bolt i cant seem to get anything on. i have tried wrenches (regular,stubby, angled) all types of sockets and crows feet with no luck any help would be greatly appreciated boost is so close i can taste it lol thanks
alan
Old Apr 7, 2007 | 03:42 PM
Mark350GT's Avatar
if i am correct in thinking which bolt you are talking about, you need to break off the end of the correct size allen key and then use a i guess a 12mm or whatever diameter the key is and turn it using that. This is what i did to connect one of the bolts on the wastegate, not sure if its the one you are talking about.
Old Apr 7, 2007 | 06:54 PM
alan21's Avatar
the allen key bolts are the ones that bolt it to the manifold im talking about the ones that bolt it to the down pipe adapter, where the exhaust gases exit into the exhaust stream.
Old Apr 7, 2007 | 09:22 PM
Audible Mayhem's Avatar
take a full size wrench and cut it so its really short, then you have to cram your hand in there and tighten it, get a few friends over to help. sometimes doing it all yourself can be crazy, also one of your friends will just do it the first time with ease.
Old Apr 7, 2007 | 11:05 PM
ttrank's Avatar
Grocery getter
Mine was done with the motor out so I can't help here.
Good Luck! It will be worth it when you are done.
Old Apr 8, 2007 | 09:42 AM
Hollywood G35's Avatar
I used a modifed crows foot. Ground it down until it fit, socket extension. Used a small amount of puddy to keep the bolt on the crows foot until bolt threaded. One 100th of a turn at a time!! Took forever!!!
If I had to do it all again, definitely would have pulled the motor.
Old Apr 8, 2007 | 12:20 PM
alan21's Avatar
thanks for the help guys ill try your suggestions and keep you guys updated ill post some pics of the install too. ^^^couldnt agree with you more next time i will pull the motor lol
Old Apr 11, 2007 | 10:02 PM
alan21's Avatar
still no luck also i cant get the passanger rear turbo bolt or the inter cooler pipe to fit one that side this is a nightmare i just wanna finish im so close any other help
Old Apr 12, 2007 | 10:58 AM
KenK2's Avatar
The Pole
Alan,
You just gotta get up there and do it man..
Bend a wrench, get someone with some small forearms to do it.. It took me and my bud 5 hours for just those 2 bolts.. It takes patience and a little bit of customizing your tool(s) to get the job done..
Most def. next time going to pull the motor!
Take your time, dont throw tools across the garage and get it done!
Old Apr 12, 2007 | 10:03 PM
QuadCam's Avatar
I definately took "some breathers" and then went back to the car after a few hours and went at it again! Just be persistant!
yosip1115
Engine - Power Adders
12
Aug 26, 2015 08:35 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
