Humming noise
Old Jul 21, 2007 | 12:13 AM
Deang35c6's Avatar
Humming noise
Need some help, guys. I recently started noticing a humming noise coming from the driver side, beneath the engine. At idle, when I rev the engine, it gets louder with rpms. When driving coming from a stop, I can hear the noise get louder, but engine noise and the supercharger drowns it out. I'm thinking its the Vortech in line pump, but I could be wrong. The car runs fine and my AFR are dead on. It sounds like a loud humming or whirring type sound. How would you know if your fuel pump was going out? Any suggestions?
Old Jul 21, 2007 | 01:46 AM
Deang35c6's Avatar
Well, I just got back from the garage and confirmed that it is not a problem with the fuel pump. The noise is coming from the driver side behind the instrument panel. The window washer fluid pump is near there, but also all the AC components. Whatever it is, it seems to be related to engine speed. Maybe it's a bad ground on the window washer fluid pump.
Old Jul 21, 2007 | 01:50 AM
Mr_pharmD's Avatar
do u have headers? If not check your pipings, plenum, and hoses to make sure u dont have any leaks.
Old Jul 21, 2007 | 06:05 AM
Deang35c6's Avatar
No headers. I have a Crawford plenum that's been on for almost 3 years, so I don't think it'll start leaking all of the sudden. The thing is that the sound is coming from the driver side engine bay or around the instrument panel. I can't hear it when I rev with the hood up. I only hear it with the down.
Old Nov 18, 2008 | 03:35 AM
Wayne List's Avatar
That Noise
Hi,
I think my 05 Coupe does something similar. At idle when in the drivers seat I here it I can't here it out of the car or under the hood.
It seems worse when the engine is up to temperature.
Did you find the cause?
Regards
Wayne
New Zealand
Old Dec 13, 2010 | 07:57 PM
shinzg35's Avatar
I have a 03 coupe with just under 80000 miles and mah car just started doing this too... im hoping its not my fuel pump.... any one else have ideas?
Old Dec 14, 2010 | 03:30 AM
Tollboothwilley's Avatar
thread revival.... not your fuel pump (its in your gas tank at the back of your car)
Old Jan 13, 2011 | 06:24 PM
aquarob566's Avatar
I have an 04', fully stock, it started making that same noise at around 69k miles and it sounds like its coming from the rear of the car on the driver side, not so loud at idle but as revs increase at times you can hear it. I'm guessing fuel pump....any ideas on this?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
