Greddy TT w/ Stock Block
Old Aug 3, 2007 | 06:09 PM
TurboDreamzG's Avatar
What's up guys, just been going over everything on the forums and been researching my FI setup I'm debating on. I wanted to see how many of you guys are running low boost on a stock block and stock internals with the TT Kit. I have heard you can run it safely as long as you dont increase your boost. so for the ones of you who are runnin it how long and how is the car holding up?
I'm thinking of going to the TT kit and leaving stock internals with low boost for now until I get up the serious cash to build it. It's my "weekend car" now cause I have just purchased a junker to drive to work so it's not my MANDITORY ride, although I want it there when I wanna drive it.
Old Aug 3, 2007 | 07:22 PM
usingthejohn's Avatar
if you go w/ greddy, go w/ the UTEC, as the e-manage the kit comes with is not that great. You can go up to 400rwhp on a stock block; beyond that and it gets a bit hairy. Some people have gone over 400rwhp, but in order to do so on a stock block, your tuning and cooling is very critical....you don't have much safety margin running +400rwhp on a stock block.
some people have gone over 40000 miles after going FI; again, it's' a matter of tuning and very good engine maintenance.
Oh, and check out the Forced Induction forum over on my350z.com
Old Aug 3, 2007 | 09:04 PM
Canadian's Avatar
Canada, eh?
I'm on JWT with stock block @ 7psi. It's perfect and drives just like stock. It is a VERY reliable kit.
Old Aug 4, 2007 | 06:18 PM
Yeah the more I research this the more I find most people have the JWT TT kit than the Greddy. Is there any differences between the two and is one more reliable and what not? Thanks.
Old Aug 4, 2007 | 06:38 PM
superchargedg's Avatar
I just put on the greddy twins(myself) and had it tuned by functiontuned and all i can say is wooooooooow.I just got rid of my stillen stage 4 s/c after 4 years and the difference is awesome and im on the stock block at 6 psi...............but not for long.You will be fine on a stock block as long as you keep it at 8 psi or below.
Old Aug 4, 2007 | 07:11 PM
QuadCam's Avatar
stock motor with Greddy TT at 10 psi with a UTEC.
400whp/400wtq @ 9 psi.
Old Aug 4, 2007 | 08:20 PM
Jtrain's Avatar
You can run 420-430 to the wheels just fine for a daily driver.
I wouldn't turn it up to 9-10 psi without intentions of doing some work to your internals however.
You don't have to do everything all at once, but you do have to do it close together.
I'm pretty sure the JWT doesn't have external wastegates, and it has smaller ball bearing turbos
Someone please correct me if im wrong-- I didin't do much research into the jwt.
Old Aug 4, 2007 | 11:52 PM
Nice...yeah I was leaning towards the Greddy but now it seems that the JWT is so more common. I found that the JWT tends to be a bit more expensive than the greddy kit, correct me if i'm wrong though. Anybody know why the JWT is more?
Old Aug 5, 2007 | 01:00 AM
QuadCam's Avatar
the greddy is a great kit that will grow with you as your power needs grow. It does this better than anyof the other kits out there.
Old Aug 5, 2007 | 11:28 AM
You hit the nail on the head.
Old Aug 5, 2007 | 11:48 AM
Zcon's Avatar
Go St
Go single turbo =] I just got a TN ST done @ 7.8 psi putting down 360 and its amazing.
Old Aug 5, 2007 | 06:58 PM
Audible Mayhem's Avatar
glad you are enjoying your ST there ian!!
go greddy, i would say that there are 10-15 greddy kits for every JWT kit out there easily.
it is a very expandable kit that will grow with you along the way. its great at 6 psi and even better at 18...
Old Aug 5, 2007 | 09:04 PM
Just curious if any of you guys had any work done by z1motorsports? I live in s.c. and I'm thinkin of takin my car to georgia to have them boyz to the motor work and install the turbo. Any feedback on those guys? I have heard a couple good things hear and there, just wanted to confirm.
Old Aug 6, 2007 | 12:46 AM
GinkyZ's Avatar
You live in Columbia, SC so do I, What part do you live in? Im Greddy TT in my in the next few weeks to plus buildin my motor.
Old Aug 6, 2007 | 05:48 PM
sharif@forged's Avatar
A safe and conservative stock block limit is about 8psi and 400whp, depending on the dyno used. The kits can definately make tremendous power in the future, if you decide to build up your bottom end.
