Mysterious squeak after 3.12 pulley install
Old Aug 15, 2007 | 01:10 AM
waijai's Avatar
i.love.gold
So upon startup my car squeaks a few times (not from slipping belt squeak). It runs ok at idle, then while driving the pulsating squeak sound starts occuring after 2300-2500rpms. I still can't figure out where this is coming from. I replaced the smooth idler pulley...didn't help. Replaced the actual tensioner pulley...didn't help. I'm going to check the tensioner pulley on the cog belt next.
Do you guys have any ideas?
Old Aug 15, 2007 | 09:15 AM
booger's Avatar
Moog
Saw this thread over at 350Z also . Check all the pulleys you had off or replaced to see if you have spacers and washers where they should be . You didnt have it before hand and have it after a pulley install . Check what you messed with . Gotta be something you did
Old Aug 15, 2007 | 09:22 AM
izmir41500's Avatar
G35driver Addict
make sure it's not your compressor making noise. that would be bad.
Old Aug 15, 2007 | 10:00 AM
s2k_g35's Avatar
You have to check on the bolts and nuts. COuld be a lose belts some where.
Old Aug 15, 2007 | 01:03 PM
Jeee35's Avatar
I’ve had a similar problem, try flipping the smooth idler pulleys around (take of and put on back the other way) one by one. Or before flipping them try spraying a little wd40 on the bearing area of the smooth idler pulleys to isolate the problem before hand. Hope this helps.
Old Aug 15, 2007 | 10:57 PM
waijai's Avatar
i.love.gold
kept re-loosening up all the idler pulleys and retightened them a few times. Finally got the squeak to go away.
Old Aug 21, 2007 | 03:09 PM
ttrank's Avatar
Grocery getter
Squeaks are common with most SC's. You may have this come and go for the life of the blower.
Old Aug 21, 2007 | 08:01 PM
waijai's Avatar
i.love.gold
Yeah the squeak came back, but goes away after the car warms up. I need to retighten everything.
snic09
Nov 8, 2017 01:46 PM
Roddy914
Aug 31, 2015 07:07 PM
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
ddietz97
Jul 26, 2015 06:16 PM
