Anybody using a vacuum manifold?
Old Aug 29, 2007 | 11:46 PM
waijai's Avatar
i.love.gold
Mark350GT has one on his car that Jotech installed. Thinkin about putting one in mine to clean things up.
Old Aug 30, 2007 | 03:09 AM
SxExCx's Avatar
uhhh..what?
pic please
Old Aug 30, 2007 | 03:47 AM
636Racer's Avatar
punish_her (mike) on My350Z uses one on his 350z.
Old Aug 30, 2007 | 07:59 AM
waijai's Avatar
i.love.gold
We designed the vacuum manifold with the turbo guy in mind. When you run a turbo, there are numerous items that require a good vacuum source. The manifold has six ( 6 ) 1/8" NPT ( pipe ) thread ports for items such as fuel pressure regulator, blow-off valve, boost gauge, boost controller, MAP sensor, etc.; and because all your vacuum sources come from one place, it makes it easier for maintenance and cleanliness, plus you only need one 1/2" Min. source from the intake manifold plenum for proper vacuum instead of having to drill and tap up to six ports in your intake manifold.
Old Aug 30, 2007 | 10:49 PM
KPierson's Avatar
I've got one on my car. It was installed by Crawford Z Car. I have no idea who made it or anything, but it looks nice.
Old Aug 31, 2007 | 12:56 PM
Drewer's Avatar
Awesome! I want one! Does it come with plugs if you don't need all six ports?
-andrew
Old Aug 31, 2007 | 05:34 PM
jdmstyleg35's Avatar
Thumbs up
-andrew
We have sold these for years.
They come in black, red, blue, polished, also with either brass or plastic fittings. The ports are not drilled all the way through, you just drill the ones you need to use. I highly suggest them for turbo guys , to clean up under the hood.
KruZZe
Feb 27, 2023 05:04 PM
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
KallDay86
Jan 8, 2016 12:42 AM
vamarris
Sep 26, 2015 12:56 PM
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
