Short Block vs Long Block????
Old Aug 30, 2007 | 02:47 AM
JDM7672's Avatar
quick questions: i know this might sound stupid but here it goes anyways. if u buy a long block there is no need to buy a short block or is it a two different blocks? thinking about buying a built short block but if a long block consist of a short block than i am buying the long block instead of short block. any information would help. thanks.
Old Aug 30, 2007 | 02:50 AM
hai109's Avatar
A short block doesn't come with the heads. A long block does...So to answer your question if you buy a long block you don't need a short block...
If you buy a short block you will need heads. Not headers...The heads where the intake manifold goes...
Old Aug 30, 2007 | 11:36 AM
Hexxum001's Avatar
^^^What he said.
Old Aug 30, 2007 | 01:56 PM
Matt at PF's Avatar
ditto
Old Aug 30, 2007 | 02:13 PM
sliderg35's Avatar
I don't know why anyone would get a short block unless that are replacing a previously purchased long block. You certainly wouldn't want to put the OEM heads back on a beefed up short block - would you?
Old Aug 30, 2007 | 02:33 PM
2slo2bfurious's Avatar
Check out the thread in my sig, I built up my longblock from a shortblock... first pic is the shortblock... everything else I added on = longblock + accessories....
Our heads flow pretty well stock....
Old Aug 30, 2007 | 02:36 PM
617G's Avatar
CFW (Carbon Fiber Whore)
^^+1 Our heads are just fine! but you can spend big bucks and port and polish them if you want
Old Aug 30, 2007 | 10:27 PM
ttrank's Avatar
Grocery getter
I am building my bottom end and using the stock heads with a little clean up.
Old Aug 31, 2007 | 08:42 AM
Dr_jitsu's Avatar
Short block will give you good reliability at power levels up to the mid or possibly upper 400's. If you want a really high hp car, then ya gotta do the long block.
Old Aug 31, 2007 | 08:44 AM
Audible Mayhem's Avatar
give us a call at the shop if you would like to find out pricing and parts for your build.
talk to you soon!!
Old Aug 31, 2007 | 10:22 PM
rcdash's Avatar
Ummm, if you mean greater than 650 whp+... then doing some headwork helps. Nothing W/M injection or really BIG turbos couldn't take care of alternatively.
Short block is just fine for any reasonable street car.
Old Sep 1, 2007 | 02:49 AM
ttrank's Avatar
Grocery getter
Wrong again in another thread.
Other viewers please see this thread for details:
https://g35driver.com/forums/forced-induction/174933-g-inherently-slow-even-400whp.html
You do not need head work until you go over 600whp.
Please stop posting false information on this forum.
Old Sep 1, 2007 | 03:16 AM
_jb's Avatar
_jb
Photographer
It always depends on what you want to do and how much money you can afford to spend.
By the time you pay to have the motor removed and a short block built... and probably turbo(s) installed, you've spent quite a bit of money. Some people decide to do the short block first and do the heads later.
It's easy to spend a couple of thousand more on just the cylinder heads. Everyone would like to get ported heads with oversized valves (maybe), new cams, new valve springs and titanium retainers, but they aren't cheap.
Old Sep 1, 2007 | 06:28 AM
It's easy to spend a 4 to 5 thousand more on just the cylinder heads. Everyone would like to get ported heads with oversized valves (maybe), new cams, new valve springs and titanium retainers, but they aren't cheap.
fixed!! to the OP, find a great shop that can take care of everything and stay loyal as long as they take care of you...
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
