Vortech Question
Old Sep 10, 2007 | 12:51 AM
sentry65's Avatar
Originally Posted by Caliboy21
bro im new 2 this websit i stated a profile 2 find some info. But i have a question 4 u, why did u get a supercharger then a twin turbo i hear different opinion on both categorys, i know the differences between them i jus wanna know witch one is better 4 my engin.
yo bro i'm nt sur wat u meen mane. like u wan 2 no wich 1 2 by???? ders tons of nfo on dis sit 2 chek out yo about wich 1 is easyer on yer engine bro
Old Sep 10, 2007 | 07:40 AM
HEGONE's Avatar
^heheh
Okay looks like I will be taking the car back to tune it anyways so I guess I'll just have it looked at and fixed there.
Finally, I use Mobile 1 10W40 fully synthetic.. Is that bad??
Old Sep 10, 2007 | 07:58 AM
HEGONE's Avatar
Originally Posted by Triji
Ok... I am NOT sure if the tensioner pulley is the same on your car or not... I have an 04...
You need to loosen the bolt in the middle of the pulley in the center of this pic 1st. This is the tensioner pulley...
Next you need to tighten this bolt (the one on the left) in incriments of 3-4 turns at a time and re-check the tightness of the belt. This bolt is located under the car near the alternater...
After it is tight to your satisfaction re-tighten the bolt on the pulley itself in pic one and you are good to go.
by the way, they are both 12mm bolts.
If you are unsure, take it to the place that did the install and have him show you 1st hand.
Good Luck!... P.S. you wont damage your engine with a slightly loose belt so it is not an immediate emergency... I would try to get to it in the next week if you cant get it in right away.
Good Luck! You will loove your Vorech! I love mine!
Thanks alot for all this info.. Greatly appreciated!
Old Sep 10, 2007 | 02:17 PM
imalazeeass's Avatar
i guess this is the time where everyones belt needs tightening.. hahahah. I still need to do mine..I was looking down from the top of the car and i noticed that the tensioner bolt is right above the sway bar and sc piping.. is it hard to reach up from there?
Old Sep 10, 2007 | 02:42 PM
Hexxum001's Avatar
How long does your belt squeal Mike. Sometimes mine does it for a sec and other times it does it up to 4-5 seconds. But after that it is fine and it drives fine too. It's just kind of embarassing when you first start it up.
Old Sep 10, 2007 | 02:47 PM
FastDontLie's Avatar
...we dont need roads...
Originally Posted by HEGONE
Yeah tighten that belt up... Also its a little hard to see, but is the cog tensioner bolt backwards. If so that may be causing some noise. Looks good.
Old Sep 10, 2007 | 03:00 PM
Triji's Avatar
The only one you can access from the top is the bolt on the tensioner pulley itself... (fig 1)
You have to tighten / loosen the tension bolt from underneath the car (fig 2)... There is no way to even get to it from above... You will need to drop your plastic undercarridge protector to get to it... To make it easier in the future you can cut a square in the protector to easier get to the bolt without having to take it off every time.
I totally took mine off and run w/ out it now.
Old Sep 10, 2007 | 03:05 PM
^^Actually I am barley able to fit both arms down the front to get to the bolts without having to get under the car. Its a bit of a fight and my arms take a little beating but it gets the job done.
Old Sep 10, 2007 | 03:16 PM
Dan_K's Avatar
You can dremel a square section out on the bottom of your undertray for easy access. Taking the undertray bolts off takes longer than tightening the belt.
Old Sep 10, 2007 | 05:53 PM
mine has done it consistently during idling.. as well as when i first turn it on.. but sometimes it doesnt do it at all. I hardly drive my car though.. so ive only heard it happen maybe once or twice.
And thanks for the reply guys.. i was actually talking about the tensioner bolt viewing up from the bottom of the car. But it seems that it should be fine if none of u have had any problems. I will do the cut square method =)
Old Sep 10, 2007 | 08:29 PM
HEGONE's Avatar
Tell me about it! Its super embarrassing when people come up to you and ask, "whats that noise all about"! lol
Old Sep 10, 2007 | 09:48 PM
waijai's Avatar
i.love.gold
I'm pretty much an expert at loosening the tensioner and tightening up the belt. It's an easy fix...14mm to loosen the tensioner and 12mm for the adjustment bolt...also need a long extension around 8-12 inches.
Old Sep 10, 2007 | 11:33 PM
HEGONE's Avatar
Umm, I don't know if someone answered this question yet but I started using Mobile 1 10W40 fully synthetic
Is this bad or someone was saying go with 0W40?? What do you guys use?
Old Sep 11, 2007 | 12:04 AM
ISMSOLUTIONS's Avatar
I use 0W40 - not the high mileage 10W40. The extreme temperature protection of the 40 and the cold start protection of the 0W.
The 10W40 - for high mileage - has cleaners and seal conditioners in the formula as well. Also, it's a higher viscosity, so it will help with oil burn off.
The standard 5W30 - is thinner, keeps the engine clean, and is designed for turbo and supercharged engines, as well as OEM recommendations.
Knowing that combustion chambers pressures are much higher in a turbo ans SC'd car, resulting is even more blowby, which will hurt performance and make the car run hotter - I go for he extra protection of the 40 weight oil with the viscosity that will keep it protected, while still keeping it thin enough to not hurt performance and help to control temperatures and blowby.
Sorry if I mis-represented anything - please correct me if I'm worng.
Rick
Old Sep 12, 2007 | 09:35 PM
  #30
i finally went to tightening my belt today... however on the tensioner bolt.. i was seriously only able to turn it a little bit because it was on pretty darn tight already. Is it supposed to be like that? My belt wasn't super loose or anything but I would hear screaching every so often. After tightening it a little bit i have not heard any squeal yet so I think its ok. I need to go for a test drive but waiting for new tires!
On a side note, I was going to remove my air filter to clean but I noticed that there was a hose connected to it? Is that part of the vortech kit or is that part of my catch can? In any event, the hose was on so tight there was seriously no room for me to yank it out. I tried for about an hr and gave up. Why does everything have to be so cramped... sigh
