Vortech Question
Old Sep 13, 2007 | 01:20 PM
  #46
imalazeeass's Avatar
wow so with it trimmed like that you can just get it out the front? clever.. but im not sure if i want to permanently cut it.. haha
Old Sep 13, 2007 | 02:15 PM
  #47
FastDontLie's Avatar
...we dont need roads...
Here is what I have sitting at home. Going to try to work this into a CAI for the vortech while still trying to have some water protection.
Old Sep 13, 2007 | 04:39 PM
  #48
ISMSOLUTIONS's Avatar
Works like a champ and increases cold air contact as well to the filter. I am doing cold air through the fender well though, in a week or so. I expect to pickup some boost as well.
Rick
Old Sep 13, 2007 | 05:37 PM
  #49
^^^You will also pick up alot more gas miles
Old Sep 13, 2007 | 05:55 PM
  #50
cruz106's Avatar
Butterfly valve
You may consider an old timer's trick using a butterfly valve try this link:
http://www.cranevalve.com/cl88.htm
just an off the wall idea for your CAI to avoid sucking water.
Old Sep 13, 2007 | 06:57 PM
  #51
yea right....maybe 1-2, if the car wasn't built or NA....for me, I plan on loosing gas mileage...that way I know the car is running its best!
Old Sep 14, 2007 | 10:48 AM
  #52
Well as soon as I went to the cold air intake I saw a big increase in my gas mileage. Which is nt saying much because my gas economy was horrible. That small vortech intake is horrible. But like you said it may be different because your built.
Before CAI-daily driving mostly highway - ~250-260
After CAI - daily driving mostly highway - ~300-310
Old Sep 14, 2007 | 12:22 PM
  #53
WOW! I wish I had that mileage. How much boost and other mods have you done? ECU? etc..
Old Sep 14, 2007 | 12:47 PM
  #54
440 inj, fuel return, 8lb boost, utec, dual exhaust, 1/2" spacer......
Old Sep 14, 2007 | 12:51 PM
  #55
OK - make it 550 inj, 10.5lbs of boost (more soon), cams and heads, some intake work, full exhaust, etc...
Minor differences ;-)
Old Sep 27, 2007 | 07:13 PM
  #56
SIN3's Avatar
this is the on going saga with this kit. this is really the only heart ache. (good trade of due to super low maintance required)
i have when i first got the kit about 2 years ago tightened the belts to tight and it snapped. sooo watch out when you do this..
i found out that after about 500 miles on your new belt you find the "sweet spot last about 5000k before you need to tighten. easy stuff after a few times....
to bad my freakin blower is out for maint....
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
