Changes to Vortech set up... need input...
Old Nov 5, 2007 | 04:20 PM
G Thizzle's Avatar
I am switching up some things on my Vortech S/C G... Recently i had a Kinetix V+ plenum and Fast Intention test pipes on my G when i originally got the car tuned...
I just recently took off the test pipes and went back to stock cats (car was tooo loud)... i also got rid of the V+ and picked up the Kinetix SSV manifold....
My question is how safe will my car be with the changes to the OEM cats and SSV on the current tune?
Old Nov 5, 2007 | 04:31 PM
Audible Mayhem's Avatar
it will change it a bit, cant really hurt to have someone take a quick look at it.
good luck
Old Nov 5, 2007 | 04:50 PM
G Thizzle's Avatar
I plan on taking it back to get re-tuned but i just wanted to know if it is safe to drive for a while...
Old Nov 5, 2007 | 04:53 PM
sentry65's Avatar
you'll probably be a little rich, that's all
G35_TX's Avatar
I would think you would be safe as long as you don't get into boost too much.
Old Nov 5, 2007 | 06:06 PM
G Thizzle's Avatar
Rich is always better than Lean.... thanks bro... i am going to take it back up within the month to get it re tuned... plus it isnt a daily driver so i hope i will be good...
Old Nov 5, 2007 | 08:06 PM
Triji's Avatar
You will actually be running slightly lean above 5500 rpm's but not too bad with the SSV ... I went from the Crawford to the SSV and that is what I noticed from the 1st pull with the SSV on the dyno. You should be ok until you get a tune but be careful in the upper rpm band.
Old Nov 5, 2007 | 08:40 PM
sentry65's Avatar
yeah but going from test pipes to stock cats, I'd think would easily negate the difference from a plenum to the SSV
Old Nov 5, 2007 | 10:03 PM
G Thizzle's Avatar
^meaning sentry?
Old Nov 5, 2007 | 11:37 PM
sentry65's Avatar
the difference between stock cats and test pipes is pretty big as far as A/F go. Going back to stock cats when you're tuned for test pipes will make you like half a point richer. Going from the kinetix V4 to SSV, even if it makes you run lean up top or not, IMO I still think you'd overall run richer because you're going back to the stock cats at the same time
Old Nov 6, 2007 | 08:39 AM
G Thizzle's Avatar
^thanks for the input sentry... just as long as i run a lil rich i am good...
Old Nov 6, 2007 | 09:55 AM
kzanard's Avatar
Do you at least have a wideband A/F so you can monitor it? The general "rule of thumb" advice here is good, but it is "general". Every car is different...
Old Nov 6, 2007 | 09:39 PM
SIN3's Avatar
you dont need to "tune" your car if you are just getting different breathing components.
your car will run just fine. i drop the stock cats and running straight pipes 2:1 single exhaust. i also dumped the stupid cheezy filter the kit comes with and had some piping made to drop a "cold air" set up. My filter sits right under my driver head light. on top of that i have headers. with all the changes. the car was never re tuned and pulls harder than ever.
you should be finel. but if you do re tune you car let me know your numbers. your car and a few others on the board i follow.
steven-
Old Nov 8, 2007 | 09:49 AM
G Thizzle's Avatar
Thanks Steven... i will let you know...
mbe32
Interior
Oct 1, 2015 09:47 AM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
n2fooz
Sep 4, 2015 07:46 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
