Defective vortechs - the nightmare continues...
Old Nov 30, 2007 | 03:36 PM
  #46
booger's Avatar
Originally Posted by FI'ed G
Wow, I thought it is just the new batch, good thing I went Turbo and so far so good. So did Vortech honor all the warranty work in 4 years?
Yes..all blowers were still under warranty .
Old Nov 30, 2007 | 05:51 PM
  #47
aero's Avatar
Originally Posted by Hexxum001
I heard that Vortech may have switched to another manufacturer for the bearings
You know what that means...guess whos making them now!?
http://news.nationalgeographic.com/n...hild-labor.jpg
Hahaha, I'm terrible.
Old Dec 30, 2007 | 09:00 PM
  #48
destinyscumn's Avatar
has anybody here done any turbo set up with a combination of a full work on the heads likeort&polished,better cams,better valves,better retainers i will like to know if somebody did it what was the diference in the final numbers after the dyno.since this will prob be the set up i am looking for thanks
Old Dec 30, 2007 | 09:39 PM
  #49
Still2Slow's Avatar
Sounds like it would be better to save up and do Greddy twins the right way. Thanks op.
Old Dec 30, 2007 | 10:12 PM
  #50
Hexxum001's Avatar
That's not the case anymore. Vortech has discovered the problem and corrected it. The brand new units that they are producing do not have this problem. See the sticky at the top of this section.
https://g35driver.com/forums/forced-induction/190323-official-vortech-statement-look-here.html
Old Dec 31, 2007 | 01:16 PM
  #51
aero's Avatar
Thanks for the reminder hex. I updated the beginning of the thread to reflect this.
Old Dec 31, 2007 | 04:10 PM
  #52
Hexxum001's Avatar
No problem. Always glad to help.
Old Jan 1, 2008 | 04:43 PM
  #53
Still2Slow's Avatar
https://g35driver.com/forums/showthread.php?t=190323
With 86K on my engine, do you think it would be a bit risky to go with FI even a SC this late? I was thinking that I might as well build the engine if I did go turbo. There's no way I would build and go SC.
Old Jan 1, 2008 | 05:18 PM
  #54
G37Rider92649's Avatar
In MY OPINION, if you really love your car, go ahead and get a SC, you do have to realize it's a bit more risky because your car is older, good luck. But if it WAS MY car, i wouldn't have a car thats 86k miles, i would've bought a new car already.
Old Jan 1, 2008 | 10:02 PM
  #55
Hexxum001's Avatar
If your engine is in good working order, why not. I believe it was Jeremy at PF that said he installed a SC on a high mileage engine and it worked just fine. As long as there are no issues with your engine, go for it.
Old Jan 4, 2008 | 04:46 PM
  #56
n2fooz's Avatar
Mine went out after about 30K miles. Bearing issue. They corrected the problem with a new style bearing.
The good news is that if your Vortech goes out just pull the blower drive belt and you can drive the car without damage. It'll just be a little sluggish because the ECU pulls timing at higher RPM's.
Old Jan 4, 2008 | 05:53 PM
  #57
sentry65's Avatar
yeah, that's something a turbo kit really won't let you do
Old Jan 4, 2008 | 08:14 PM
  #58
booger's Avatar
If you havent made any fuel changes , or EMS changes to your system [ injectors , return fuel stystem , or Utech EMS ] The cars ECU will learn its self back to stock . And with in a short time drive just like stock . It will NOT pull timing as if in boost in the upper RPM's . The SS box will not pull timing unless it is in boost .
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
