Vortech Upgrade with 440 Injectors
Old Nov 28, 2007 | 01:58 PM
dreamsmith's Avatar
I have a g35 coupe 5AT, just got my internals
Arias 9.0 pistons
Eagle rods
arp L19 head stud
arp main stud
(Thanx to sharif@forgedperformance )
and i have got a 440cc injectors
now am running vortech with stock pulley with emanage
i was wondering which belt i can upgrade for the vortech, without facing any issues with slippage or changing my injectors? (dont forget i have a 5AT, with just cooling upgrade)
Old Nov 28, 2007 | 02:05 PM
waijai's Avatar
i.love.gold
If you have a built bottom end, you should be able to do the 2.87 pulley (non rev up), but increase inector size to say...650s.
Old Nov 28, 2007 | 02:07 PM
Hexxum001's Avatar
You want to know which belt to upgrade?? Or which pulley to upgrade??
dreamsmith's Avatar
whats my options if i stick with 440 injectors for now?
Old Nov 28, 2007 | 02:18 PM
Hexxum001's Avatar
I'm running the 2.87 with 550cc injectors and a Walbro fuel pump and it works fine. But belt slippage is something that can happen even with the stock pulley. So there really is no way to completely eliminate that issue. Over time, belts wear out and/or stretch which will cause some slippage. Also, if you upgrade to the 3.12 pulley, you don't necessarily need to upgrade your injectors but it is probably a good idea to do so and get a tune. With the 2.87 pulley, you would definitely need to upgrade your injectors and also get a tune.
Old Nov 28, 2007 | 02:23 PM
dreamsmith's Avatar
so will i be running with 3.12 with no fuel issues, or is it a 50/50 chance ?!
from what i understand i just need to order the 3.12 pulley nothing else need to be changed right?
Old Nov 28, 2007 | 02:59 PM
Hexxum001's Avatar
With the 440cc injectors, I think that you will fine with the 3.12 pulley.
Old Nov 28, 2007 | 03:29 PM
Triple8Sol's Avatar
With your setup, you should skip straight to the 2.87 and get some 550's or 650's. I'm running the 3.12 w/440's at the moment.
Old Nov 28, 2007 | 03:32 PM
Gilley's Avatar
I have the 3.12 pulley and 440 injectors, which are controlled by a UTEC and Walbro pump.
If you go to the 3.12 pulley, you will need a shorter belt than the belt you have with your 3.33 puley.
With your 5AT, you might want to consider a valve body kit too.
Old Nov 28, 2007 | 04:18 PM
dreamsmith's Avatar
how much whp are you getting on your car?
Old Nov 28, 2007 | 04:38 PM
booger's Avatar
A tranny fluid cooler and a VB will help save your tranny and help it shift better . Best mod for a F/I AT5 . 440 injectors maybe good enough even for a 2.87 pulley . Depending on other mods you have . Why upgrade the injectors until you actually need to . Im running the T-trim blower with 20psi and 550 injectors and Im still ok......for now.........after I get it all working right , I may need to go to 650's .
Old Nov 28, 2007 | 04:57 PM
Dan_K's Avatar
There are a couple people running the 2.87 pulley with 440cc injectors. The injector duty cycle is almost max'ed out, but its possible.
Old Nov 28, 2007 | 05:35 PM
Hexxum001's Avatar
550's are definitely a better option with the 2.87. Better to be safe than sorry.
Old Nov 28, 2007 | 05:50 PM
booger's Avatar
If you are tuned safely with 440's and dont have to increase the fuel preasure to get there . 550's are just over kill . It does not making it any safer !
Old Nov 28, 2007 | 06:41 PM
Hexxum001's Avatar
If the 440's are maxed out or close to being maxed out, that's definitely not a good thing. My point is that 550's tuned correctly is more than enough and he wouldn't even be close to maxing out. 550's are not overkill.
