Vortech pulley...
Old Dec 5, 2007 | 10:52 AM
Deang35c6's Avatar
True, but it doesn't feel like 410rwhp. I actually feel a power loss and that's probably from the ECU adjusting timing from the lower octane.
Edit: My EGTs have went up since I've moved here. That's another sign of retarded timing.
Old Dec 5, 2007 | 11:21 AM
booger's Avatar
I dont know what the elevation of Chicago is , but Socal is sea level basiclly and Im sure the weather is quite different . Your tune isnt in the same area of your maps and it isnt running the same because of it . I dont think it has much to do with the gas you are using .
Old Dec 5, 2007 | 01:46 PM
Sportcoupe35's Avatar
So with a conservative tune, would you say its safe to run the 3.12 pulley on a stock Vortech setup...would this eliminate the need for a tensioner pulley mod?
Old Dec 5, 2007 | 03:42 PM
Deang35c6's Avatar
The pulley tensioner mod is nice, but if you have no problem making 9-10 psi without it, then don't bother. It really comes in handy with the smaller pullies.
Old Dec 5, 2007 | 09:47 PM
1FSTG35AT's Avatar
I think im going to have to get the 3.12 pulley then get a tune and i also have the injen track exhaust and the 5/16 spacer installed on my car so I definately need a tune!
Old Dec 5, 2007 | 09:56 PM
Audible Mayhem's Avatar
very nice man!! i cant believe you have it all installed already. you dont play around.
we usually see 20-25 more hp with the pulley change from 3.33 to 3.12, we also see another 20-25 with the 2.87 pulley.
i love superchargers!!
let me know if anyone needs anything, i will take care of my fellow members for sure...
Old Dec 5, 2007 | 11:36 PM
1FSTG35AT's Avatar
yeah Jeremy I started installing it the day it got to my house... It only took me about 12 hours to do it. Just worked on it a couple of hours everyday after work...
Old Dec 7, 2007 | 01:49 AM
Bashar368's Avatar
I made 50 whp and 20lbs torque with 3.12 and a tune. big difference in power
Old Dec 7, 2007 | 12:10 PM
Triji's Avatar
I never installed the 3.33 pulley, I started right out with the 3.12 and dyno'd on a DD at 390hp (410 dyno jet corrected). at 8.8psi... I am now hitting 9.4 psi consistantly with the GTM mod and still using the 3.12 pulley.
I have a 2.87 in my garage waiting to go on but do not want to install it until I get my injectors / utec installed which I also already have. I wish time grew on trees...
Old Dec 7, 2007 | 01:00 PM
Mr_pharmD's Avatar
i think your numbers might be alittle inflated. If u were stick then maybe but autos u seeing around 370hp on dynojet with your mods.
Old Dec 7, 2007 | 11:37 PM
Triji's Avatar
You might be right, I'll look for my dyno sheets since it was awhile ago... I usually dyno on a dyno dynamics, I did dyno on a Dynapack last tho... I'll try to find that dyno laying around...
If I remember correctly, on the dyno dynamics at DynoComp I saw right around 374 and from what I recall to equate to a Dyno Jet you ad 10% to that to get to 411.4ish...
I gotta find the dynos but nevertheless, we all know dynos compared to other dynos are almost meaningless and they are more of a tuning tool.
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
