single or twin
Old Dec 18, 2007 | 04:35 PM
  #46
TURBOTOM's Avatar
a.k.a kleicoupe
Originally Posted by 617G
only the fact that the Greddy hits full boost at 3.5k lol
When does the T-netics kit hit full boost?
Old Dec 18, 2007 | 04:37 PM
  #47
617G's Avatar
CFW (Carbon Fiber Whore)
Originally Posted by FI'ed G
So are you going down to Zdayz Airport Runway on May? I'm not worthy to battle with those guys so I'll meet you up on the Freeway on your way down. I think one of the rule for ZDAY is no Trailer Queen so you are going to have to drive down there
Also I want to see some logs after the race to make sure you are on your LOW Boost!!! lol
lol, you'll have to keep up with me and r0mey on the way down
Old Dec 18, 2007 | 04:39 PM
  #48
FI'ed G's Avatar
I have some Cowboy friends and I'll bring them and bring some rope!!!!
Old Dec 18, 2007 | 04:44 PM
  #49
FI'ed G's Avatar
It all depend on What PSI. Most TN Dyno that I have seen range from 3500-4400rpm on 9psi. Greddy can hit full boost at 3500rpm at 12psi
Old Dec 18, 2007 | 04:46 PM
  #50
RANC3R's Avatar
Hey Alvin.. speaking of zday i wanted to cruise down with 4 or 5 guys if your interested
Old Dec 18, 2007 | 04:47 PM
  #51
617G's Avatar
most TN kits don't reach peak tq until about 4,400-4,500rpm, whereas the Greddy is at peak torque at 3,500...this is assuming the stock block 9psi
Old Dec 18, 2007 | 04:52 PM
  #52
FI'ed G's Avatar
/\ +1 most of them (TN) usually hit Peak TQ at 4200-4400 but peak boost usually happen a few hundred sooner than that. For Ex. I hit my Peak TQ at 4100rpm on a 4th Gear pull but my Boost hit peak at 3900rpm. On a 5th gear pull I hit my peak boost sooner around 3400rpm - 3500rpm.
Old Dec 18, 2007 | 04:54 PM
  #53
617G's Avatar
/\ +1 most of them (TN) usually hit Peak TQ at 4100-4400 but peak boost usually happen a few hundred sooner than that. For Ex. I hit my Peak TQ at 4100rpm on a 4th Gear pull but my Boost hit peak at 3900rpm. On a 5th gear pull I hit my peak boost sooner around 3400rpm - 3500rpm.
that's because there's more load on the engine in 5th gear
Old Dec 18, 2007 | 04:56 PM
  #54
FI'ed G's Avatar
I was just going to maybe meet up with some in the freeway and maybe stop at Maryland/Virginia and see some friends. Not sure if I will go all the way to NC
Old Dec 18, 2007 | 05:04 PM
  #55
RANC3R's Avatar
in that case youd be there before you knew it
I will never lease a car again in my life.. 3 yrs wasted without FI
Old Dec 18, 2007 | 05:05 PM
  #56
FI'ed G's Avatar
Yes, gearing is everything. Are we talking about all 4th gear pull here? 5th gear is were we have 1:1 ratio and I'm not sure what gear are all of those TN Dyno that I have seen. It is very hard to compare since there is to many variable to consider.
  #57
Hexxum001's Avatar
pu$$y
Hey, the fines here in Cali are really steep.
Old Dec 18, 2007 | 05:07 PM
  #58
617G's Avatar
all dynos should be in a gear that is 1 to 1 (5th for 6MT and 4th for 5AT)
Old Dec 18, 2007 | 05:09 PM
  #59
FI'ed G's Avatar
/\ I can relate a little since I was nervous when I had my Inspection done a week ago. Ether way if I had failed, I know people who can pass me I'm happy I'm not in Cali!!! but I envy your weather and nice flat Roads compare to NYC
Old Dec 18, 2007 | 05:10 PM
  #60
617G's Avatar
btw, I'll be in NYC one weekend during the winter to get something done to the car if you wanna meet up
