Need help with gauges for TN kit.
Old Dec 28, 2007 | 09:35 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Hey,
I'm having my TN kit installed very soon, and I want to get a good set of gauges. I want to get Boost, Oil Pressure, and Wideband. I think I'm going to go with the Defi Boost, and Oil Pressure, and the Inovative Wideband. I have just a couple questions about the gauges.
-What color do I want to get the Defi gauges in to match the interior? Amber? Also it seems like there are different levels of gauges, Imperial, BF, ect. Which ones should I get??
-The Inovative Wideband (X-16) comes with like 16 different combos of faceplate, and a bunch of other stuff, but Do I need a "control unit" like the one that the Defi gauges need to use this gauge??
-How do the Autometer nexis gauges compare to the Defi, they are only a little bit more money, and if they work better, and read more accurate, then I would rather just spend the extra money and get those. Which gauges are the better of the two??
-Is there such a thing as a knock-off gauge, I have seen some very good prices on ebay, for new gauges from ebay stores, but I'm not sure if they are legit or not. I know there were alot of knock-off "Tein" springs being sold on ebay, and I dont want to waste my money on a knock-off chinese boost gauge.
Also does anyone have any recomendations on where to purchase the gauges, Vivid racing seems to have the best prices, so far, but I also got a good price from a loacal shop, and I wouldnt have to worry about shipping. If you are a forum vendor, send me a PM if you could with a price for all of these gauges too.
Thanks in advance
-Tom
Old Dec 29, 2007 | 01:07 AM
sliderg35's Avatar
The nexus gauges are not as bright as Defi. I usually switch to white during the day and use the OEM amber colour at night. It's not a big deal, just something to consider when weighing all the factors.
Old Dec 29, 2007 | 01:21 AM
TURBOTOM's Avatar
a.k.a kleicoupe
When you say they are not as bright do you mean that in a good way, or do you mean that they are hard to read because they are not well lit.
Also that made me think of another question, is the brightness setting on these gauges adjustable, I cant stand bright light when I'm driving at night, I turn the cluster down to as dark as it can go, to the point where it is about to shut off.
Old Dec 29, 2007 | 12:56 PM
sliderg35's Avatar
There are 5 settings of brightness. They are absolutely perfect at night, but during the day, the amber isn't as bright as I would like it to be able to read the gauges the easiest. I use the highest illumination all the time - even at night. I am sure you would be happy with the amount you can turn them down.
Old Dec 29, 2007 | 02:53 PM
Mad A's Avatar
As for the innovative wideband X-16, all you need comes with it, the wideband controller, the bosch sensor, and the gauge. You don't something additional in the cabin like the Defi control unit. It's a great wideband, you might have to recalibrate it every now and then though.. if you ever disconnect the battery, etc.
Old Dec 30, 2007 | 10:18 PM
ttrank's Avatar
Grocery getter
I'm going with Nexus WB A/F, Boost, EGT, Oil Press, Fuel Press and Oil Temp.
I was looking at the Defi but like that the Autometer are 52mm and all match. It would be nice if Defi would make a A/F again.
Old Dec 30, 2007 | 11:28 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Yea its too bad that Defi dosent make a nice Wideband. Why did you decide to go with 52mm instead of 60mm? Also thats alot of gauges that you are getting, where are you going to put them all?? lol.
Old Dec 30, 2007 | 11:32 PM
caelric's Avatar
Nexus gauges are more than bright enough for me; I think I have them at the 3 (out of five) setting for the day, which is not too bright at night. Also, they have changeable colors using the remote, and the amber color perfectly matches the interior gauges on the G. Finally, you can put a SD card in the remote, and record the gauge readings for playback later.
I don't know anything about the Defi gauges, but I am very happy with my Autometer Nexus's. I've got boot, oil press, and oil temp in a 3 gauge A-pillar pod, and fuel press and wideband as part of my double DIN setup.
Old Dec 31, 2007 | 05:46 PM
ttrank's Avatar
Grocery getter
The #1 reason was I found a great deal on some of them used.
I am going with A/F, Boost and EGT on the A-pillar and the other above the HVAC display.
Old Jan 9, 2008 | 05:27 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Anyone know who has the best price on the Defi's????
Got a gauge pod, and Innovative Wideband already.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
alessandro
Oct 8, 2015 09:29 AM
9tray turbo
Sep 29, 2015 10:22 PM
JustinMKN1
Sep 18, 2015 03:40 PM
