Vortech Cog Belt
Old Jan 12, 2008 | 09:59 PM
imalazeeass's Avatar
Vortech Cog Belt
Well my cog belt seems to be shedding teeth.. a good section of the belt is missing teeth which causes some weird noises when driving. So I've got to order a new cog belt and swap it. Can someone advise me on how to change the cog belt? Thanks.
Old Jan 12, 2008 | 10:57 PM
Mr_pharmD's Avatar
loosen the bolt on the cog side off the 3.12 pulley and u should be able to slide the old belt off and the new one in.
Old Jan 13, 2008 | 04:04 AM
clifftrail's Avatar
I'd loosen/remove the tensioner/guide pulley for the cog belt and it will provide you with enough clearance to change the belt.
Old Jan 13, 2008 | 07:48 PM
booger's Avatar
I'm not trying to sound like a ***** , but if you cant just look at it and see how to take it off and change in a new one . Maybe you better let a shop do it . Its a pretty simple and quick change out . 3 or 4 minutes tops for me .
Old Jan 13, 2008 | 08:10 PM
you're right.. its pretty straight forward. I was just being lazy. I posted a thread b4 actually looking at it. Thanks for the replies guys.
Old Jan 15, 2008 | 12:04 AM
istan's Avatar
I was just being lazy ***.
Oh Really? It's simple. However, is the blower eating belts or has it just worn out over time?
Old Jan 15, 2008 | 04:43 AM
just worn over time
Old Jan 15, 2008 | 12:47 PM
istan's Avatar
^Cool. You'll be good to go then.
Old Jan 17, 2008 | 11:44 PM
well after ive switched out the cog belt, everything has been running fine.. no strange sounds at all.. but when i was visually checking it, i noticed that the side of the belt is rubbing the side of the tension pulley. It seems that the belt is not exactly centered on the tensioner pulley. Has anyone come across this problem? I will post pics tomorrow to show what I mean.. but no matter how teh belt is adjusted, it will always move back to the same position. Its leaving some marks on the pulley...
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
reaper76
Sep 20, 2015 11:59 AM
n2fooz
Sep 4, 2015 07:46 PM
