pro charger
Old Jan 16, 2008 | 03:45 AM
svtray's Avatar
pro charger
I have a 05 g35 with a procharger.Right know i am running 7.5 lbs with a stock motor and it put down 340 whp. My question is when i change my exhaust and put a plenum spacer in what size pulley do i need to get 400 whp,and how much boost can the motor handle safely. Thanks
Old Jan 16, 2008 | 09:35 AM
rockd's Avatar
i am running the X02 exhaust, motordyne 5/16 plenum spacer, 440 injectors, walbro fuel pump, and an emanage ultimate with the stock ATI pulley... and I'm close to 400whp. A lot of it depends on the tune...
No one knows EXACTLY how much the motor can handle safely. All i know is that ATI sells a 7psi, 9psi, and 11 or 12 psi kit. Higher than that is probably dangerous...
Old Jan 16, 2008 | 09:44 AM
mrimage's Avatar
the current mod i have are ATI Procharger, 440cc injectors, AAM Basic return system, walbro 255, Utec EMS, Turbo XS Racing Bypass Valve, AAM plenum spacer greddy SP exhaust with high flow resonator, "custom cold air intake through my radiator support for the supercharger" note, by doing this my boost presser rise and the car is more aggressive. i am putting down 373.9 round off to 374 whp. i am currently running the standard 7psi pulley, but it boost to 9psi.
Old Jan 17, 2008 | 01:50 PM
IrockAG35's Avatar
Ohio G Club moderator
so getting the exhaust and spacer he wouldnt have to change his pully's...just get it retuned?
Old Jan 17, 2008 | 02:02 PM
Hi-TechG35's Avatar
Anything over 400whp and no build is asking for trouble. The more you boost with out a build or tune the more dangerous it becomes.
Old Jan 17, 2008 | 02:24 PM
svtray's Avatar
I understand that I will have to get it tuned when ever i upgrade anything.I am wondering what kind of power does the motor handle with stock internals.
Old Jan 17, 2008 | 09:34 PM
G37Rider92649's Avatar
Get your internals if you're going near or over 400whp, sooner or later......Kaboom! JK...Just get internals...not happy with 340whp?
Old Jan 18, 2008 | 11:10 AM
svtray's Avatar
340 is a good number but 400 sounds a little better.I want to upgrade a few thing and 400 seems to be reasonable number.thanks
Old Jan 18, 2008 | 06:24 PM
zazaracing's Avatar
Team Transport Member
Ive had from 390-408rwhp on my g for 60k miles and 30 or so tracking days. stock internals with the ATI. You can do it but each motor is different. with a good tune you should be fine. I have the stock pulley and get 8.5-9psi as well. I just upped to the 14psi pulley so we will see if we can break the 500rwhp mark.
Old Jan 18, 2008 | 06:48 PM
Xblackg35X's Avatar
^VERY NICE!!! let us know how it turns out
Old Jan 18, 2008 | 07:36 PM
SDGeneralCounsel's Avatar
the FI section on the my350z boards are the place to go for these types of questions.
Old Jan 19, 2008 | 01:04 PM
IrockAG35's Avatar
what kind of internals should be changed after or aroiund the 400whp margine?
Old Jan 19, 2008 | 01:15 PM
Xblackg35X's Avatar
rods pistons and piston rings
Old Jan 19, 2008 | 01:54 PM
IrockAG35's Avatar
any particular brands i should keep in mind for this upgrage?
