View Poll Results: What gauge should I get?? Already have Wideband and Boost.
Oil Temp.
10.00%
Oil Pressure
21
42.00%
Fuel Pressure
4.00%
E.G.T (Exhaust Gas Temp.)
12
24.00%
Other, and please let me know why.
2.00%
I have no clue what gauge you should get?
18.00%
Voters: 50. You may not vote on this poll
Help me decide what should be gauge number 3!?!?
Old Jan 17, 2008 | 09:24 PM
Jtrain's Avatar
EGT is old school- I vote oil temp. Helps at the track and day to day trying to figure out when you are really over heating and when you're warmed up.
Old Jan 17, 2008 | 10:00 PM
FI'ed G's Avatar
Originally Posted by kleicoupe
Heres how I see it....
Oil Temp - will let me know when the oil is warmed up and I can start boosting, also will lret me know if I'm overheating.
true but you can use the Oil Pressure as a guide if the Oil is warmed up. I know it is not the best way but on cold start or the first 5 mins your Oil Pressure tend to be a little high, so what I do is wait for it to get to normal then that gives me an Idea.
Old Jan 17, 2008 | 10:12 PM
pjames's Avatar
i'd say EGT, since any problems will show up there first. if you know how to interpret the temps when used in collaboration with other gauges you can determine if your a/f is off, if your timing is off, even if you have a carbon build up (increase in compression) etc.
oil pressure gauge would be up there too, though.
Old Jan 17, 2008 | 10:25 PM
Good & Tight's Avatar
Oil pressure gets my vote, could save your engine if you blow an oil line. It's also a good way to monitor your engine in a sense that you get used to seeing a certain oil pressure at different rpm or on start up and when hot.
Old Jan 17, 2008 | 11:49 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Okay as far as the oil pressure goes, will it show a loss in pressure if there is a leak, or will it let me know if it is a more seriosus problem like a broken line? Sorry for all of the FI noob questions, but I am new to the FI thing.
Old Jan 18, 2008 | 10:39 AM
sliderg35's Avatar
A broken line will show when the pressure drops to Zero! I have Nexus gauges and the Oil gauge will turn red if that happens. Really hard to miss it.
Old Jan 18, 2008 | 01:50 PM
caelric's Avatar
Actually, the Nexus gaues (which I have) are programmable; you can set the alert feature to anything you want. So, you can set the boost gauge to alert if you overboost (at a programmable boost level), the oil temp gauge to alert if you go over a certain temp, the pressure to alert if you go under a certain pressure, etc... All alert levels are programmable.
In addition, the Nexus gauges are color changeable, and the orange matches quite well with the G35 stock gauges.
All in all, I love my Nexus gauges!
Old Jan 18, 2008 | 05:52 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I cant decide if I want nexus of defi imperial either, I think they are both even?
Old Feb 9, 2008 | 10:35 PM
BadBoy06's Avatar
take a peak at these, I will be running the boost/ext/oil pressure with innovate/wideband
http://prosportgauges.com/premium_se...ng_gauges.aspx
as for your question............oil pressure
Old Feb 10, 2008 | 03:27 AM
TURBOTOM's Avatar
a.k.a kleicoupe
They look nice, do you have any reviews on them?
Also are you still getting your car done at VTR, if you are let me know I want to stop by the shop and see it.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Gwhut?
Sep 19, 2015 11:33 PM
Danielek
Sep 10, 2015 06:18 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
