400HP with Vortech...what needs to be done?
Old Jan 18, 2008 | 11:32 AM
joe603's Avatar
I know that I could put on a twin turbo kit and make 400HP, but I want to do the install myself...and turbo's are much more involved. So, I'd like to do a supercharger...most likely a Vortech. My question is, what needs to be done to have it hit 400HP. Budget is a concern...to a point.
Can I simply get the base Vortech kit with a smaller pulley? I already have the MREV2, Spacer, Stillen TD exhaust.
Is it even possible to do with the Vortech (400RWHP) without getting into internal engine mods?
Old Jan 18, 2008 | 11:39 AM
617G's Avatar
CFW (Carbon Fiber Whore)
you have a rev-up, so just add the 3.12 pulley, get it tuned, and you will be at 400whp+ I would suggest 440cc injectors and a better EMU than the Split Second box as well. Your internals will be fine.
Old Jan 18, 2008 | 12:06 PM
joe603's Avatar
Excellent! So the tuner kit would be the best bet...maybe a UTECH?
Old Jan 18, 2008 | 12:08 PM
istan's Avatar
Tuner Kit + 3.12 + 440s + Walbro 255 + Utec or better would be a good choice. Although, I am still on the split second and my tuner seems to be happy with it. (Saving Money FTW!)
Old Jan 18, 2008 | 12:22 PM
617G's Avatar
Utec or Emanage Ultimate will do the job just fine.
Oh, and yes, get a Walbro 255 as well.
Tuner Kit FTW!
Old Jan 18, 2008 | 01:36 PM
sentry65's Avatar
he has a revup, so the revup kit comes with a 3.12 pulley to start with...he can either get a 2.87 pulley, or get the same cog pulleys from the non-revup kit
Old Jan 18, 2008 | 01:39 PM
617G's Avatar
^^ i didn't know that...cool
Old Jan 18, 2008 | 02:16 PM
joe603's Avatar
neither did I! So is it a higher boost with the REVUP version?
I'd love to have your numbers BTW!! (sentry65)
Old Jan 18, 2008 | 02:59 PM
sentry65's Avatar
yeah the revup kit out of the box can reach higher whp than the non-revup because of the higher redline and how that plays into the hp equation (tq x 5252/rpms). I'm not really sure why they changed things the way they did. Maybe they thought the 3.33 pulley was too large for the belt layout they designed and so went with the 3.12 and changed the rear cog pulleys to bring the boost back down - I don't know.
Either way I think the revup hits a slightly higher psi at the redline than the non-revup kit.
Old Jan 18, 2008 | 03:09 PM
istan's Avatar
The thing I noticed about the 3.12 on the revup. You can't seem the be able to change the belt without taking the M'Fer off the bracket. The 2.87 gives you enough room to slide it under and change the belts.
Old Jan 18, 2008 | 03:23 PM
Skaterbasist's Avatar
Retired SuperMod
Shouldn't be hard, as many have already stated. Definately get some HFC/TP's, as that helps out alot.
Most important part is that you make sure the tuner knows what he's doing.
Old Jan 18, 2008 | 03:43 PM
FastDontLie's Avatar
...we dont need roads...
Would say get at least 550cc injectors if your shooting for 400. And maybe a water/meth ket to get you there safely.
Old Jan 18, 2008 | 04:30 PM
joe603's Avatar
550!! 440 seems high to me... I guess it would help with preventing a lean condition, but if a 440 fails, so could a 550.
Old Jan 18, 2008 | 04:49 PM
Trust me, I have 440cc right now and really wished i would have went with 550cc or 650cc. 440cc would be closer to making out the injectors if your looking to make around 400whp. Also recommend the Utec for EM. Just my opinion.
Old Jan 18, 2008 | 04:50 PM
G35Asian's Avatar
I'm running 650's with a walbro 255 fuel pump and she runs perfect (including idle)
