Big Problem Last Night
Old Jan 19, 2008 | 01:46 PM
IrockAG35's Avatar
Ohio G Club moderator
so last night went to a movie...went to start the car, and made a screeching noise,and then wouldnt start..turned it over once again..then started..but was running rough...as we drove to the house..stopped for gas..filled up while car was runnig..the car died on the spot...went to turn it over..and it was like the gears were seized up..the motor wouldnt turn...so i popped the hood...and noticed the main drive gear on the procharger had been ribbing against the mounting bracket..and had actually melted together...any reason this would have happened?..i wound up taking the gear off and drove it home...also there is a hose under the hood that has just come off from where ever it was connected and is pumping off what smells like burnt oil/exhaust any idea what this is?
thanks for your help
Old Jan 19, 2008 | 10:23 PM
IrockAG35's Avatar
pics of the gears
couldnt take pic of hose...its about 1/2in line under the blower on the procharger
Attached Thumbnails Big Problem Last Night-second-date-pro-pics-029.jpg   Big Problem Last Night-second-date-pro-pics-027.jpg   Big Problem Last Night-second-date-pro-pics-024.jpg
Old Jan 19, 2008 | 10:25 PM
G37Rider92649's Avatar
Ouch! I have no i dea because I'm not a mechanic but by the looks of it, that does not look good at all. Please update us as you fix this issue, so we all can have a heads up if this ever happens to one of us.
Old Jan 19, 2008 | 10:27 PM
IrockAG35's Avatar
nice g same fnt i think
befor ati kit was installed...no fmi
Old Jan 19, 2008 | 10:29 PM
IrockAG35's Avatar
ill keep you guys informed..ill probably find out whats going on with it on mon..hopefully not to much internal damage was done..i checked to see if that drive gear was loose beforre i took it off..it was on there extremely good..i have no ideah why this happened..ill call ati and see what they have to say..hopefully under warranty..
Old Jan 26, 2008 | 01:32 PM
IrockAG35's Avatar
well it seems that the whole kit comes pre assembled...i dont know if this is true but its what ati told the shop that installed the kit.so they have decided to give me @ no cost a whole new kit...so im stoked about that...epp is comming to the house to put it on this week...wish me luck...and most of the time if its within a year you can claim that the part is faulty and ati procharger should replace it for no cost!!
Old Jan 27, 2008 | 03:24 PM
IrockAG35's Avatar
and nasty they are...ill keep you posted
champppy
Mar 31, 2020 12:25 PM
Mick_L
Aug 25, 2015 04:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
