how to loosen belts for stillen sc install
Old Jan 19, 2008 | 06:45 PM
diablo1356's Avatar
just need some quick help...im in the process of installing my stillen sc, and i need to loosen the oem belts in order to get some of the stillen pulleys on. ive removed the bolts from the oem pulley in order to remove that, but i still need to get the belt off. how do i loosen the belt? i think its the main one, the serpentine i believe. thanks!
Old Jan 19, 2008 | 06:54 PM
rookie's Avatar
You loosened the idler pulley and it won't come off?
Old Jan 19, 2008 | 07:15 PM
diablo1356's Avatar
the one that diagram is talking about is not the pulley i need to replace with the stillen one. its the idler pulley above that one. so if i just loosen the tensioner bolt from the bottom of the car, the belt should slide off right? and i dont think by just taking off the bolt the pulley will come off regardless...im assuming the belts are on tight, so the pulley is also being held in place by the belt...correct me if im wrong
Old Jan 19, 2008 | 07:37 PM
rookie's Avatar
A holds tension, B sets tension that part should be the tensioner. You may need a pulley puller to get the idler pulley you're talking about off.
Old Jan 19, 2008 | 07:47 PM
diablo1356's Avatar
so if i just loosen b, the belt wont loosen? the stillen instructions just say take of belt and pulley, and ttrank had told me its just four bolts. im pretty sure i dont need a pulley puller, i just need to loosen the belt.
Old Jan 19, 2008 | 07:50 PM
rookie's Avatar
That's right the IP is just 4 bolts. You need to loosen the tension on the tensioner to get the belt off, A locks the pulley in place so it doesn't loosen up with the belt.
When belts are loose the pics are the adjustment point to make them tighter.
Old Jan 19, 2008 | 08:04 PM
ttrank's Avatar
Grocery getter
Rookie's right. You need to loosen the nut on the pulley so it can move and then use B to move it down.
Old Jan 19, 2008 | 08:11 PM
diablo1356's Avatar
just to clarify, that pulley with the nut on it IS NOT the pulley being replaced by the stillen double pulley correct? so i just loosen the nut on the pulley, turn that bolt under the pulley counter clockwise, the belt loosens, and belt comes off...correct? i sound like such a newb, but i wanted to do this install myself so i can learn more bout my car. wow this install is gonna be fun!
Old Jan 19, 2008 | 10:12 PM
GreenGoblin's Avatar
The goblin resurrection
take pics of your install
Old Jan 19, 2008 | 10:34 PM
diablo1356's Avatar
yeah thats what im doing..hopefully ill be the first diy stillen installer.
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
EricF
Aug 28, 2015 08:27 AM
Team STILLEN
Aug 10, 2015 08:17 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
