stillen or vortech- still have ?
As a new poster to this thread I hope to have appeased those of you who say do a search with reading lots of posts and searching, yet I myself have some questions about stillen vs. vortech.
I've read that the stillen has more hp/tq low end, but has very limited mods that it likes as well as is limited within itself. I also have seen several threads where the customer service has been less than par, and lastly that getting warranty work honored has been an issue. Lots of red flags.
I haven't seen the posts on poor vortech service or hard to deal with warranty issues (but I may have not searched deep enough either) I have also noticed that most say the out of the box vortech doesn't have the strong response low end as the stillen does, but that this can be adjusted with mods...one question is how much money to get that response?
As for kits- do both come with full install kits - (everything needed) and detailed install instructions for a DIY install?
My wants are...I want to stay on the stock block and be within safe tolerances as this would be a daily driver. Commuting to work-mainly interstate and then some spirited drives on the weekend (not track or drag)
I like the low-end hp/tq that the stillen provides but those red flags sort of sway me, then again if it is an extra 5K for that low end on a vortech I might just be willing to roll the dice.
Is it recommended with a stillen Stage 2 or a vortech with the base pulley (can;t remember number) to have some sort of management system, or is the system that ships with them suitable?
All input is welcome- I have not decided either way.
Have you considered a Turbonetics single turbo kit? They arent that expensive compared to the twin turbo kits on the market. They seem to put down a good amount of hp/tq on a good conservative tune. They come with everything you need and I bet its a breeze for a DIY. Just tossing that out there.
I have not reasearched the turbo market that much. I've heard about the lag that they have. I do like that there are no belts to potentally break- which is I guess another question, how have the belts stood up to the tests of time? I will do research without asking noob turbo questions. But I would still like comments on the superchargers. Does anyone in the TN area have a single turbo, stillen stage 2, or basic vortech?
83K miles on my car, 40K miles on my Vortech w/ 3.12 pulley. I have never broken or snapped a belt. I went w/ vortech over turbo because I wanted reliability (I live in the desert and turbo's got to hot out here)... I wanted a more linier pull to help the tranny last longer. I did not want to build my block and wanted a safe FI. If you dont mind 400 - 450 whp and hitting boost at 3000 - 3500 rpms and want a safe and reliable FI.... I like the Vortech
As I understood it, turbos get alot hotter than the Cent SC's and alot more can go wrong / it is harder to find issues as well.
I pull 9.5 - 10.1 psi in the cooler months here with the 3.12 pulley. In the warmer summer months I hit 8.8 to 9.5 psi normaly. What that equates to in horsepower loss however, I do not know.
sc vs turbo
wow
Originally Posted by sentry65
this thread has lots of vortech info
http://www.my350z.com/forum/showthread.php?t=270770
Have you heard of boost leaks with the MD 5/16 spacer kit? Is it accepatable to run a spacer, or should a modded plenum like crawfords be used instead of the spacer?
