oil filter spacer
Old Mar 5, 2008 | 01:09 PM
CHudson Coupe's Avatar
oil filter spacer
where is the best place to get an oil filter spacer? I need one that allows me to screw my oil pressure sensor into it. I've tried the search already.
Old Mar 5, 2008 | 01:50 PM
Drewer's Avatar
most people get sandwich plates from www.summitracing.com.
Or, lookup the "oil cooler DIY" on my350z.com. They list a bunch of plates to get sandwich plates.
Second. . .doesn't the oil pressure sensor go inline with the sender somewhere? (I just don't know. ) I need to get a oil pressure gauge too. . .
Old Mar 5, 2008 | 03:02 PM
My guage came with a sensor that needs to be "T"d in, it mentioned that I could just replace the stock one, but I don't want any warning lights or errors going off. I will be installing a turbo supply line by T'ing into where the stock sensor is. I just don't want all those fittings in one spot, so I think i should just get the filter spacer and use the holes that come with that, reducing the amount of T's that I will need (hopefully less chance of leaks).
Old Mar 5, 2008 | 03:40 PM
How do I tell which one from JC whitney will fit my G?, does anyone already have one?
Old Mar 5, 2008 | 03:48 PM
coupes-r-tits's Avatar
Some of you might laugh, but i made my own. I went to the local hardware store and bought a couple fittings and made a "T". It doesn't leak at all, and works just fine. The best thing, it cost me about 2 bucks total!
Old Mar 5, 2008 | 03:57 PM
Haha, well whatever works right? I found one, if anyone else is interested here is the link. http://www.glowshiftdirect.com/index...ROD&ProdID=200
I've done some looking around, but no real good answers, which oil filter for FI application? I'm planning on using Mobil 1 0W-40 oil.
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
Machine Head
Sep 4, 2015 07:22 PM
ClwMike
Jul 23, 2015 12:55 PM
