Technosquare Flash on 03-07 Turbo ?
#31
Originally Posted by supercowboy
Who has tested them?
Stand alone would be great, But then the you would some of the drivability that the car has from factory. Also if you drive on the stret how would you go through emissions. Fmu is a time of the past and I dont think any g turbo kit comes with one.
These are all "band aid" fixes to what the stock oem computer can do.
What? have you driven a standalone EMS? You are kidding right? Try find someone with a Vpro and tell me if it doesn't feel stock when driving. hhmm even with a reflash, your A/F will be set to around mid to low 11's when on boost so how is that going to change the emission? Dont tell me the Reflash will run the same A/F as the stock ECU... I don't know why you are such a fan of a reflash and yet non of the Pro shop will recommend them FI'd cars. Gees, you call the Fcon, Haltech a band aid fix???? spending $4k on EMS is a band aid to you I think you have no idea on our cars!!
Edit:
Tell my how your Almighty Reflash tune for the Street were altitude change and how can it tune every load point on the Map? Unless you have a load base dyno and you spend 20hrs of tuning every load point then how many flash are you going to do?
#32
Originally Posted by FI'ed G
FYI, Utec is not just a Piggyback, it is a Parallel EMS where it takes full control of you injector/timing when on Boost. Utec don't scale value like other piggyback which rely on what the ECU want to run and they just subtract/add from it.
OP
You can only do so much with a Flash and you'll end up going back a million times if you do a million thing on your car. How does a Reflash take into account partial throttle tuning or DD? You can send them you dyno but they are mainly WOT run so what about other Cell/Load points that you will not hit on a dyno? If you already have a reflash then don't go back for another one, just bite the bullet and get a Utec or better since you have a much better control. Not to mention you can do your own logging so you'll see if your tune is actually still spot on. You can't look at your gauge 100% of the time you know and how do you know if you are getting light knock?
#33
I understand how the utec works But does it work with the on board diagnostics and emissions?
#34
hhmm even with a reflash, your A/F will be set to around mid to low 11's when on boost so how is that going to change the emission? Dont tell me the Reflash will run the same A/F as the stock ECU... I don't know why you are such a fan of a reflash and yet non of the Pro shop will recommend them FI'd cars. Gees, you call the Fcon, Haltech a band aid fix???? spending $4k on EMS is a band aid to you I think you have no idea on our cars!!?
Edit:
$600 or so for reflash
$3000 plus install and many hours of tuning.
Tough choice.
#35
when you are not on Boost the ECU takes control of everything since you are NA at that point. Once you hit boost Utec take full control of the Injector using pulse width with its own table for fuel and it has its own table for timing that will use without any interference from the ECU.
Let us go to the next level and that is a Full Standalone (FCON, Haltech, Pro-efi), these EMS has greater resolution and can auto adjust themselves when something got changed and much more control.
#36
/\Hey I was waiting for you guys to respond.. lol Will a reflash affect ODB2 inspection? I have been curious about it but not sure if I'll have problem with Inspection in NY. Can you also PM me price and details, I have a Utec and sometimes I do get some knocking on ECU Control especially in the summer and around 2700-3200rpm. Not also sure if a Reflash will solve the Part Throttle (Utec back to ECU control) jerkiness when going out of boost with Utec.
#37
Yes I have, Point is this takes alot of time to tune right. It will fail emissions because they can not plug into the diagnostic ports, and the big picture is cost. How many people here want to spend $3000 to tune there car after they spent $6000 to buy the kit?
You still keep the ECU since it still control other things in the car. If you spent $6000 for the kit then why not spend extra money to protect your investment?
Have you driven a car with a stock computer that The parameters been changed? Most new stuff including the G has much faster processors, parameters, etc. in the ecu that many stand alones dont offer. Pro shops are there to make money "Period". I am just looking to make things run smooth good drivabilty and make the car haul ***.
Have you seen the Pro-efi and what processor it uses? So you have driven a G35/350Z with a Turbo/SC using a Fcon? then if it is not smooth like stock then there is something wrong.
The stock set up in the G35 has air temp sensors, barometer, etc. The stand alone, you have to buy these things and most of them cannot support them. How does the stand alone compensate for this. most pro stuff is for the pro that constantly make changes for different climate. The stand alone has a base map to get the car running. The stock ecm already runs and drives with no issues.
You have to upgrade your MAF first before you can go above 4psi with the stock parts. 99% of FI'ed cars here uses Speed Density with a MAP sensor (MAF is so yesterday) and Standalone uses the o2 sensor to adjust itself. Pro-efi also has an adaptive learning capability, meaning once it relearn the changes it automatically save them so they don't have to re-learn it again.
You are absolutely right. I agree with you. You still have to do this with a stand alone. My opinion is if you can make the changes with the stock ecm what would you need the stand alone for.
The $600 reflash are Cookie cutter, you have to spend hours of dyno tuning and countless of reflash to get the best tune (not just a gauge) since how do you know how the car will react at 30F and 3000ft of elevation and 3000rpm and 10 psi of boost unless you actually tune for that? Also add the cost for the upgraded MAF which I have no idea if someone ever did that to a G35/350Z... What work with a Supra may not work for a VQ you know...
Tough choice.
Tough choice.
You seem you know a lot about cars but you seem to forget you are talking about a different car here and it took years and many blown motor before all this pro shop and EMS manufacture re figure out what works...
#38
Originally Posted by Jeff92se
True. But as it was suggested before, the reflash would take care of the closed loop operations and the aftermarket ecu would take care of the open loop operation. Reason why you would need both is because the reflashing guys don't have the ability to scale for a larger maf. The aftermarket gets around this by going speed density.
Reflashing can take care of bigger injectors (scaling) but I don't think too many companies have much experience with it. Reflashing can in theory rescale for a bigger maf but I don't think they've actually done it. Adress these two and the reflash could take care of everything. Well they might want to add boost altered timing/fuel maybe.
#39
So this is a piggyback
What Changed? most ems make the car run what you have programed it to do. If it alters it than what is the use of a stand alone? Is this a race car now or do you drive it on the street. I know the stock ecm can do all that most of these can do. Just by looking at the software for the stock ecm reflash stuff.
For example, the most timing advance you want to run at peak tq is 13-14 deg, on the day of tuning you saw that the ECU like to run 18 deg advance at 4000rpm and 8psi, now you set your Map to subtract 6. Now the weather got a lot hotter and the ECU decide to run only 15 deg timing advance. Now your map is still subtracting 6 so now you are loosing more power. With Utec you have a specific number there regardless of ecu. It maybe safe but subracting to much will also race your EGT...
#40
Car has 6 pistons and 24 valves right! This has been around for many years. Im sure many pro shops have blown up motors I dont disagree. All people who make ems systems dont care what the factory Ecu does, because they are not "there"(ecu). When you go to this extreme you fall into a money pit. This is what people try to avoid when its there weekend driver.
#41
Your tune most not be right. I would go back and have someone tweek the UTEC. If you get a reflash you would have to tune the UTEC again. The flash would change many parameters to make it right so now the utec would be tuned for you previous set up. these system fight each other this is why you want one or the other.
Have you worked with Utec? why will it change? Utec will run its own timing regardless of what the ECU wants when on boost Utec could care less what the ecu wants, ECU can cry all he wants and there is nothing it can do since Utec control the injector and Timing 100%. I wanted the flash since I do get knock on ECU control and not under Utec control at around 27000rpm and 32000rpm and that is all. If I do get knock under Utec then I can always tweak the Utec Map to add fuel or pull timing.
#42
You can look at it that way but a most piggyback only scale what the ECU value, meaning it just add/subtract from that. Utec don't care what the ECU run since it has its own specific value regrdless of ecu. For example, you can set to subtract 10 at 4000rpm and 8ps on your timing map, what if the ecu decide to run higher timing?
#43
#44
When you scale for injectors you have to deal with the idle and low rpms so there are some alterations done with the UTEC also. Car will not run properly with 550 or 750 cc injectors unless you scale them. The UTEC only knows to pull back 6 degress at 4000 rpm and 8 psi. It cannot take away less timing because that is what the UTEC is controling ( 6 degress of timing)
Also Utec has an active Knock control, meaning if it detect knock, then you can set it to pull timing on your own terms. When knock is detected, ecu tend to panic and pull a lot of timing than what it should so performance suffer. I can also do my own logging with utec so I can review the data later own.
Utec cost $800-$900, a cookie cutter relfash cost $600.. now you still need to tune your car if you are FI'ed with a reflash so what are you saving? With utec, you get the logging capability, Active knock control, be able to do minor adjusment...
#45
NO.. Piggyback add/subtract to the ecu value but not utec. For example, at 4000rpm and 8psi, my Timing Map has a value of 13 in UTEC (that's around my peak TQ), this mean my car will run 13 deg advance at 4000rpm and 8psi regardless of what the ecu wants. This is what I meant of total control. With a piggy back you just subtract or add from the ECU to get the value you want, this is not the case with utec and that is why it is consider a parallel EMS and not a plain old piggy back. Utec also will scale a bigger injector and that is through the 0 column. If you are not on boost, the Utec will run the 0 column of your Fuel Map for fueling and the rest of the column will have a specific pulse width numbers to control the injectors. This is what I meant that Utec has its own values that the tuner can predefine to use without under the mercy of the ECU. If I want 15 deg timing advance at redline then that is what I will get! You know ECU change value depend on temp//octane/altitude right, well I don't want to depend my tuning on what the ecu will run.. get it?.
http://www.uprev.com/
They have real time datalogging also.
