Nitrous question
Old Apr 15, 2008 | 03:56 AM
importroller's Avatar
Nitrous question
Before you go flaming, Im not new to the nitrous game, just new to it with a car that has a returnless fuel system as well fly by wire TB. I was debating about putting nitrous on my altima just for kicks once in awhile (g is gonna be Turboed) but i was curious, since my altima is a 6spd manual, how to you do the WOT switch with no actual external moving parts for the TB for it to know when to engage? also, where do you tap into for the fuel? Is it on the feed line? other than that, i think the rest of the install should be pretty much the same as I had in my old car.
Old Apr 15, 2008 | 02:03 PM
GTM's Avatar
GTM
TPS is easy, most nitrous systems come with a module (if not sold separately) that you can tap into your OEM TPS signal (0-5v) and program the TPS curve so the unit knows when you are WOT.
Fuel is easy as well, Get a SPX fuel adapter, with longer bolts, and sandwich it between the OEM FPR and OEM fuel rail, then you can screw a fitting on to the adapter and provide fuel to your solenoids.
I would also recommend a digital window switch, setup to spray between 3,000-6,000RPM, Also don't red line your engine when on the juice.
Good luck, I had nitrous on my Z for a while back in 03, lasted for a while until I stretched a few rods, pistons started slapping the heads, went back to stock and got it warrantied though
-George
Old Apr 15, 2008 | 05:08 PM
good info
Old May 21, 2008 | 11:20 PM
Quick question, If I bought just a regular wet kit, is it gonna be a pain to find individual parts to make it work with a fly by wire setup, or is there a kit with all the parts already there for me?
Old May 21, 2008 | 11:45 PM
Red_G35's Avatar
-George
how much were you spraying?
Old May 22, 2008 | 12:30 PM
RedondoG's Avatar
The parts you need are all available from dynotune.com, at pretty reasonable prices too.
Old May 23, 2008 | 01:40 AM
from what i've been reading on other sites, a wet kit with a TPS switch is all I would need? or is that incorrect? Last car I had nitrous on used a regular TB, so it was pretty easy to do everything.
Old May 24, 2008 | 01:15 AM
RedondoG's Avatar
get a combination tps / window switch, 1 step colder plugs, bottle heater and a remote bottle opener.
Old May 24, 2008 | 01:20 AM
speedracerg35's Avatar
that toolbag totolus did a diy on a g35 sedan on that show tricked out. i'm pretty sure a lot of it will carry over to a 3.5 altima. he used an under pedal switch for wot position.
http://www.diynetwork.com/diy/ab_par...680966,00.html
Old May 28, 2008 | 05:10 PM
ttrank's Avatar
Grocery getter
+1 Good list.
Spray is good as long as you stay off it most of the time. If you use it a lot you are better off spending the money on a turbo so. All the gas adds up just like a payment on the boost.
I had a car on the bottle a while back and won't do that again because I used it too much and had nothing to show for it when everything was over.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
TheBay
Sep 3, 2015 03:27 PM
