Which Meth injection kit?
Old May 18, 2008 | 07:33 AM
  #31
Dan_K's Avatar
I never said the gains would be great, but you can have gains with pure water if you tune for it.
The problem with running 100% meth is when you do that, you need to decrease the amount of unleaded fuel you are spraying for correct AF significantly and so if the meth pump fails, it's instant BOOM.
Adding 100% water without a retune is unlikely to give you more power, but your car will run more consistent and be safer. Water WILL decrease your IAT's just as well as meth. The combustion process is very unlikely to be slowed down enough with atomized water, unless you are dumping it in and have a poorly designed controller.
More power can be had with 50/50 mix of meth water without a retune. You will run a bit richer, but because of the fuel properties of meth the combustion with be cleaner, cooler and more efficient. I'm assuming the car is tuned correctly ~11:1 and adding the meth mix should drop it to ~10.5:1 which is still ok. Now, with a specific tune for the meth mix by increasing timing and leaning out the AF mixture more, since it is safe to do so, gains will be optimal.
Just look up the chemical properties of the two liquids.
Old May 18, 2008 | 12:58 PM
  #32
FI'ed G's Avatar
/\ Yes, you have to run a good ems and need a retune when running pure meth because of the dramatic A/F drop, not to mention the kit should be able to handle pure meth. Pure meth is also corrosive (Some people will disagree) and that is why I don't like it. This is just me coz if I'm spraying then why not add a small amount of meth (20%-40%) just to have that added octane/fuel instead of pure water alone. 30% meth will not affect the A/F that much and can be run without a retune. As a matter of Fact Snow Performance state that don't touch the Fuel map but instead change the Nozzle around until you get a drop of .5 on your A/F. Snow advice to rather increase timing or run more boost instead of touching the Fuel Map (In this is with a 50/50 mix). just my .02
Old Jun 4, 2008 | 01:53 PM
  #33
nuclearcarnie's Avatar
Quick update. I installed my Snow Performance W/I system. It starts spraying at 7 PSI. I am running just 40% Meth/60% Water and did not do a re-tune. The car is much smoother under boost throughout the RPM range, it also feels quicker. I was going to wait for a re-tune before installing but am glad I didn't.
Old Jun 4, 2008 | 04:58 PM
  #34
FI'ed G's Avatar
how do you know you are running 40/60? Did you do your own mix?
Edit: What size of nozzle are you using?
Old Jun 5, 2008 | 12:54 PM
  #35
225 ml/min nozzle (What they recomended for my baby hp numbers) and I cut the methonal/water mix with distilled water to approx. 40% methonal.
I tried a 25% mix at first and then added more Methonal and it seemed to run even better. I will try 50/50 mix but won't be going any more than that. I think I am accomplishing what I wanted for now. No more pre-detonation, smoother power.
Old Jun 5, 2008 | 02:07 PM
  #36
FI'ed G's Avatar
Mixing meth and water should be done by weight because they have different weight. If you mix it by volume then 1/2 a gallon of Meth and 1/2 a gallon of water will give you somewhere 40% meth and 60% water. To make 1 gallon of mix, you need .44 gallons water and .56 gallons meth (1.67 L water and 2.12 L methanol).
Methanol weight 6.6 pounds/Gallon
Water weight 8.34 pounds/Gallon
Old Jun 19, 2008 | 01:08 PM
  #37
Sinister350GT's Avatar
Nice thread Now I am off to buy the Snow Performace Kit!
Old Jun 19, 2008 | 02:37 PM
  #38
Jtrain's Avatar
I always figured meth/water was to add timing.
I got one sitting on my dinning room table- I may slap it on and spray water until I build my motor. But then again- I dont really care. Interesting thread- Thanks
Old Jun 19, 2008 | 08:12 PM
  #39
G37Rider92649's Avatar
I like my snow performance kit
Old Jun 19, 2008 | 08:23 PM
  #40
str8dum1's Avatar
^^ do you have taht kit spraying before the MAF? looks like that in the pics. thought that was a no no.
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Rhinos7777
Sep 6, 2015 05:36 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
