finished vortech install
Old Apr 8, 2004 | 05:08 PM
  #31
tig488's Avatar
Re: finished vortech install
at idle my blowoff is continuously discharging a ton of air. is that correct, or should it not be doing that?
BS/Graph 6MT Cp
19" GunM TE37 275/30 MPSports
kg/mm,cambers,cuscosways,injen int/exh,Alpine/JL/Stinger,topsecret
Vortech
Old Apr 8, 2004 | 05:13 PM
  #32
tig488's Avatar
should i adjust the screw on the top of the BOV, i guess the seal plate isnt closed all the way?
BS/Graph 6MT Cp
Vortech
Old Apr 8, 2004 | 06:19 PM
  #33
GforceI's Avatar
G SQUAD
Freaking sweet install man. Congrats on the blower I didn't know that they were that cheap. Not that 4000+ is pocket change but I figured that FI was a minium investment of at least 6k. So is this a little B-day Present for yourself? If it is Happy Birthday. Cant wait to see that dyno.
Old Apr 8, 2004 | 10:47 PM
  #34
zimbo's Avatar
BOV should not always be hissing. Sounds like it needs to be tightened.
--Steve
Old Apr 9, 2004 | 01:54 PM
  #35
Chris's Avatar
That does sound odd, I'm not too familiar with Superchargers, but do these kits come with external wastegate type of devices? Or is it constantly expelling the boost out of the BOV?
Congrats on the install!! That must of been fun, I would definately do that myself except with the TT application, i don't plan on removing headers and such, LoL. Awesome job!!
Old Apr 9, 2004 | 06:36 PM
  #36
Profile4's Avatar
2x check your vacuum line and tighten the blow-off valve bolt...those are the only ways i can think of that are wrong with your BOV causing it to leak, if that doesn't resolve your problem you may need a new BOV. i experienced slight whistling w/ my BOV under vacuum conditions, which theoretically shouldn't occur, but did anyway.
04 DG/G/6MT/Premium/Nav/Clear Bra
Bone Stock...to be continued...
"You kill mah brodah, now I kill you!" - some old kung-fu flick<P ID="edit"><FONT class="small"><EM>Edited by Profile4 on 04/09/04 03:39 PM.</EM></FONT></P>
Old Apr 10, 2004 | 01:28 AM
  #37
n1cK's Avatar
G35 6MT
the blowoff valve should definitely not be continuously discharging. everybody has the right idea in saying that boost is necessary in order to open the valve. it's basically a relief valve, where a spring is set to open. if it's continuously opening, there must be something wrong with the setting or the spring.
but it's a great looking install tig! glad to see you did it yourself (with some help of course). that's probably the best part (imho). can't wait to see the results of the dyno either. i'm new to the g35 crowd and am not too familiar with the "ss box." is it a stand-alone or a piggy back? again, congrats!
n1cK
jUs' bE [img]/w3timages/icons/cool.gif[/img]
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
